Help with AEM EMS base map
Old Nov 5, 2006 | 08:21 PM
Dsgs2k3's Avatar
ask some other turbo users, or you can ask inline pro as they probably have it
Old Nov 6, 2006 | 05:27 AM
Ultimate Racing's Avatar
Check to see that you haven't already fouled your spark plugs.
If all is well do this...
1) Open up the base map calibration that comes with the AEM EMS
2) Go to the main fuel table, right click and select Change injectors/pressure
3) Fill in the info for Old and New Injectors. Try 360cc @ 43.5psi, and 750cc @ 43.5psi
4) Change the injector battery offset table for your injector
5) Save it...upload it...set your throttle range....and try starting the car
While cranking, look at parameter Stat Sync'd to see if it's turning ON.
If you see it come ON and it's struggling to start, try to gauge if it's too rich or too lean. If it's too rich, try starting it with your foot WOT.
This should most definitely get your car running. If not, something else is going on.
Keep in mind that you shouldn't be driving on this basemap. I wouldn't even do this without a wideband to be honest. But if you're only driving it onto your trailer it should be fine.
Darryl
Old Nov 6, 2006 | 10:24 AM
pushin9's Avatar
Ok I talked to my tuner this morning and he sent me a base map for me to try. I will be changing my plugs and trying this new map tonight. I hope the S2K starts! And now I have an appointment for a full tune on Thursday at 10am!
Old Nov 6, 2006 | 10:33 AM
JDM S2000's Avatar
Banned
where you getting tuned
Old Nov 6, 2006 | 11:02 AM
pushin9's Avatar
My tuner is Luke at Beyond Redline in Green Bay, WI
www.beyondredline.com
Old Nov 6, 2006 | 12:05 PM
pushin9's Avatar
[QUOTE=pushin9,Nov 5 2006, 09:06 PM] I have been trying to register there for over a week now! They never send me a confirmation e-mail so when I try to open the files it says I need to login but I can
Old Nov 8, 2006 | 10:20 AM
pushin9's Avatar
Can someone please confirm that I am loading my base map into the EMS correctly?
Here is what I am doing:
1. plug EMS cable into computer
2. turn key to on position
3. open up aempro program
4. connect to EMS
5. Click ECU -> Send new calibration (shift + F8)
6. Then find the base map I want to upload and click open
Now if I do those steps is my new base map loaded into the AEM EMS and it should be ready to go correct?
Old Nov 8, 2006 | 12:01 PM
4. connect to EMS
Correct.
Old Nov 9, 2006 | 12:04 PM
pushin9's Avatar
***********UPDATE 11-9-06*********
OK as many of you may now know I just installed the AEM EMS 1052U and was having trouble getting my car started. So many of you were kind enough to send me base maps to try. I appreciated all your time and help however still couldn
Old Nov 9, 2006 | 03:57 PM
JDM S2000's Avatar
Banned
darn, didnt you buy that used?
