HELP im scared of fuel wash!
Old May 14, 2013 | 05:39 AM
Japmuscle's Avatar
Default HELP im scared of fuel wash!
I have been driving my car on the highway for about 3 days now (im driving across canada) and I was hoping you could answer me a question.
I have been keeping the car out of boost as per my tuners recommendation (he tells me its safe to run the car in vaccume but the tune is still incomplete for boost), but I have noticed that the AF gauge has been moving between about 13.8:1 and 16.5:1 and back on intervals of about 5 seconds from one end to the other. This is during highway driving under consistent light load (cruising).
I have noticed that the oil in the car smells strongly of gas and I am concerned that the car is running rich causing a lot of gasoline to get in the blow-by gasses (fuel wash down).... also the valvetrain seems to be making more noise than normal (although this could be purely my paranoia)
I have changed the oil several times just to be safe (about once per day), but I am still quite concerned.
Also on another note: each time when I changed the oil the check engine light came on shortly thereafter. This also happens when I let the car just sit and idle for more then a minute. After i shut the car off for a few minutes (10-20) and then turn the ignition on the 'need service' indicator flashes a few times and the check engine light isnt on anymore...
when i asked the mechanic what the car was doing in one of these instances he plugged the OBD2 diagnostic tool (he connected it as a honda s2000, not an RSX I donno if that was wrong seeing as how the hondata is based on an RSX ecu) and told me the following codes were thrown:
cylinder 3 and 5?? were misfiring
the airpump was not functional
2 of the o2 sensors werent reading correctly
Is this a tune issue, a bad couple of stock 02 sensors, or something else???
The set-up on my 2002: inline pro stage 1, hondata kpro, straight exhaust (no cat), PLX wideband
Thanks SO much,
Jeff
Old May 14, 2013 | 01:03 PM
starchland's Avatar
Your reading from stock 02 sensors which are narrow band ? Or your wideband?
Old May 14, 2013 | 01:28 PM
XxMerlinxX's Avatar
That A/F ratio, if the numbers are correct, is actually lean and not rich. How you're getting that kind of A/F ratio, but managing to dump fuel into your oil, I don't know. Broken piston ring maybe? If it is actually running rich, your plugs will foul (which may be the misfire codes) and you'll start to develop a lot of soot on your back bumper. You can also develop popping in your exhaust as unburned fuel is expelled from the engine and ignited in your exhaust system.
Old May 16, 2013 | 05:11 PM
Japmuscle's Avatar
thx for the info guys... I spoke with jeff evans and Tom at inline pro and both reassured me that the car was ok before finishing my long road trip.
the cars tune is good for drivability just under boost jeff evans said I should go through a few more revisions before i was good to rape the car.
I spoke with a couple of expert mechanics here and jeff evans again and the issue is the promary OEM o2 sensor seems to be getting 'lazy' (making readings every couple seconds instead of a bunch of time per second) so I just need to get that replaced, and Im good to go hopefully...
also I was taking the readings from my wideband PLX gauge, but the car doesnt run off of that reading under partial throttle
Japmuscle
May 16, 2013 05:10 PM
jsenclosure
Mar 6, 2012 05:08 AM
waytooslow
Jul 14, 2009 07:10 PM
nightcrawler7188
Jan 2, 2008 08:04 AM
S2K_LA
Apr 21, 2004 12:22 PM
