help me to control the heat. ( part 2 )
Old Oct 26, 2007 | 09:13 PM
s2guru's Avatar
Lightbulb help me to control the heat. ( part 2 )
So the issue is with the brake line. what are you guys using in the brake line?
Old Oct 27, 2007 | 12:50 AM
Tolgahan Ures's Avatar
You definately need a heat shield there . You can also try removing the long plastic piece below the windshield wipers , it helps venting the hood.
Old Oct 27, 2007 | 06:49 AM
Spec_Ops2087's Avatar
Vented hood and relocate your fuse box to the fender.
Old Oct 27, 2007 | 07:40 AM
ShMooveS2k's Avatar
is there a DIY to move the fuse box to the fender? ive heard about it but havent seen it. and is it a PITA to do it like that
Old Oct 27, 2007 | 10:29 AM
AirborneS2K's Avatar
what size turbo is that? GT35?
Old Oct 27, 2007 | 10:33 AM
RacerXI's Avatar
I'd relocate the fuse box.
Old Oct 27, 2007 | 10:57 AM
There is a thread somewhere with some pictures, do a search for it...should give you an idea of what to do.
Old Oct 27, 2007 | 11:27 AM
s2guru's Avatar
yes,
i think i found a good solution for now.
i went to autozone and found this.
http://www.designengineering.com/pro...sp?m=sp&pid=32
What you guys think?
ShMooveS2k: relocation of the fuse box is not a easy task, it will take time and you need to know what you are doing.
Old Oct 27, 2007 | 06:18 PM
EG-B18cR's Avatar
Originally Posted by s2guru,Oct 27 2007, 11:27 AM
yes,
i would do that with a heatshield as well
youll be fine after that
Old Oct 27, 2007 | 07:43 PM
afwfjustin's Avatar
I have a heatshield for mine and it fixed my heat issues completely
