Help with mounting Vortech AC radiator.
Old May 11, 2009 | 06:02 AM
stack's Avatar
Default Help with mounting Vortech AC radiator.
I have been working on (slowly) installing a used Vortech kit. I was about to install the coolant reservoir, water pump, and radiator for the after cooler but can't seem to figure out how exactly the radiator is supposed to be mounted.
When I bought the used kit I knew there were some parts missing including the mounting brackets for the radiator. The previous owner said that he had the radiator welded on. I ordered the new brackets from Vortech but they don't seem to be the correct ones. The picture in the current Vortech installation manual shows the radiator to be light / silver in color, with the inlet and outlet on the short end of the radiator. The radiator that I have is black with the inlet and outlet on the long end of the radiator. I am wondering if Vortech had revised the radiator design at some point.
I have seen pictures in DIY's, written on this site, that show the same style radiator as I have but none of the picture clearly show how it is mounted.
Could somebody please post a picture showing how the radiator is mounted?
I will post pictures of what I have versus what the manual shows tonight.
Thanks in advance.
edit pictures added
Mounting brackets that Vortech sent me:
Radiator that I have:
Picture from installation manual:
Old May 11, 2009 | 02:20 PM
stack's Avatar
pictures added
Old May 11, 2009 | 06:29 PM
Slows2k's Avatar
Those brackets don't look like the ones on my old kit
Old May 11, 2009 | 06:44 PM
stack's Avatar
Which radiator did your kit have?
Old May 11, 2009 | 07:07 PM
Slows2k's Avatar
It looked like your 2nd pic.
Old May 12, 2009 | 02:40 AM
stack's Avatar
Do you remember what your brackets looked like? It seems to me that they would just be a simple "L" bracket, probably with two holes on each side of the "L".
Pardon my poor drafting skills.
Old May 12, 2009 | 03:53 AM
Slows2k's Avatar
Ha, They actually did look like that. 2 at the bottom, and one at the top corer than bolted under the hood latch corner bolt.
Old May 12, 2009 | 05:22 AM
stack's Avatar
[QUOTE=Slows2k,May 12 2009, 06:53 AM]Ha,
Old May 12, 2009 | 09:10 AM
stack's Avatar
Originally Posted by stack,May 12 2009, 08:22 AM
Did the bottom two look like the top one shown in your pictures or are they different?
Please ignore my question. I talked to Vortech during lunch today. I am returning the brackets that were sent to me and they sending the correct ones.
Thanks for your help.
JS2k.com
Oct 3, 2010 04:51 AM
legendman
Mar 21, 2009 02:36 PM
hmss2000
May 19, 2005 03:53 PM
johninator
Nov 12, 2004 06:54 AM
RCR S2
Aug 9, 2004 04:33 PM
