Help Needed with Identify Injector -
Old Oct 13, 2012 | 01:25 PM
iDomN8U's Avatar
Default Help Needed with Identify Injector -
are these Injector Dynamic 1000 with 00-05 plug and play clips (ID1000)?
Can anyone verify please?
Thank you!
Old Oct 13, 2012 | 03:27 PM
starrman's Avatar
I have id1000's and granted it has been a while since I actually looked at them...but mine don't look like that. The seals on the ones in the pic look old and cracked...maybe they are an older version?
Old Oct 13, 2012 | 05:50 PM
Reapur's Avatar
You're judging them by worn rubber seals? Obviously the ones shown are used.
I have id1000s too, maybe it's because there's nothing to show scale, but mine don't look that beefy. Mine seem to have smaller diameter bodies. It could just be an optical illusion though.
Old Oct 13, 2012 | 06:08 PM
kryptonite's Avatar
Member
Spotter
I googled the number on one of the injectors and found this. (googled 0280158117 injectors)
http://boschdealer.com/index.php?mai...products_id=31
http://www.vivaperformance.com/bosch...fuel-injectors
not sure if that would identify the housing type or the actual injector
Old Oct 13, 2012 | 06:28 PM
iDomN8U's Avatar
it's my understanding that injector dynamics take a bosch injector and change them to thier own spec.
I just wish they would put some sort of identifier after they modified the injector
Old Oct 13, 2012 | 06:30 PM
Reapur's Avatar
Yeah seriously, how hard would it to print ID1000 on the body ? lol
Old Oct 13, 2012 | 06:33 PM
iDomN8U's Avatar
probably because I had to use a macro lens to capture the text on the injector body
Old Oct 14, 2012 | 06:45 PM
iDomN8U's Avatar
Anyone?
Old Oct 14, 2012 | 06:49 PM
miguel329's Avatar
Did you buy used?
Old Oct 14, 2012 | 07:01 PM
iDomN8U's Avatar
Originally Posted by miguel329
Look like my regular bosch 1000 i habe in f/s section.there was a good write up i found on google for id identification. Did you buy used?
I believe ID1000 are bosch bodies that have been modified, so they look the same
