High boost supercharger guys
Old Sep 24, 2007 | 09:27 PM
CourageOO7's Avatar
Default High boost supercharger guys
Guys,
I am thinking about getting a much smaller pulley on my CTSC (like 3.2 or 3.4 inch) on my stock HG and lowering my rev limiter to 8 or 8500 rpm.
The idea is to increase torque/hp in the lower rev range (lowering vtec engagement to like 4200 rpm) and not use all 9000 rpm to ease valvetrain abuse.
I am building a track car and I thought the smaller pulley might really help with low end. I would keep rev's low to keep intake air temps reasonable and also to ease the burden on the valvetrain.
Can I get your thoughts? Sideways and JohnZ? Anyone else?
Thanks in advance!
Old Sep 24, 2007 | 09:43 PM
Enthralled's Avatar
do you have a dyno of your current setup?
Old Sep 24, 2007 | 09:49 PM
CourageOO7's Avatar
Kind of, this is tuned on a VAFC 2. I've already got the AEM EMS:
CTSC/AC, 440cc injectors, HKS exhaust, Megan TP, DC headers (gay, I know...came w/car), stock boost
Old Sep 24, 2007 | 09:51 PM
Enthralled's Avatar
what numbers are you looking to get in your mid range?
Old Sep 25, 2007 | 02:54 AM
fltsfshr's Avatar
It looks to me like you need to retune with your aem. drop your vtec engagement into the 4400 4500 range. It will smooth out your power curve and give you smoother acceleration. That way you won't find boost and vtec all engaging at once as you come out of a corner. If you run a test pipe as well, you'll find some nice hp gains at midrange rpms and can tune so you build hp all the way to 9g rather than reducing your max rpm to accomodate a smaller pulley.
fltsfshr
Old Sep 25, 2007 | 04:40 AM
CourageOO7's Avatar
This is a good question. I guess the answer would be "more."
Old Sep 25, 2007 | 04:45 AM
CourageOO7's Avatar
fltsfshr
My dyno plot is old, it's tuned on a VAFC 2 and I mentioned at the top that I am going to drop my rev limiter to keep air intake temperatures down and reduce valvetrain wear.
Old Sep 25, 2007 | 02:13 PM
CourageOO7's Avatar
So no more input than this, huh?
Old Sep 25, 2007 | 02:27 PM
Enthralled's Avatar
I have my Vtec set at 4.5k.maybe you should drop yours also, it may help with the mid range.
Old Sep 25, 2007 | 02:30 PM
Enthralled's Avatar
heres my dyno done a couple weeks ago(dynojet)
I have a 4.4"(about 8 psi) pulley with 550 injectors.tuned on a Emanage Ultimate.
other mods ACT clutch and a test pipe.
I have a Vortech, but just to show you........my mid range jumped about 20whp/20tq after the tune.
