High hp engine mounts
Old May 29, 2019 | 04:04 AM
mys2k3's Avatar
Default High hp engine mounts
I’m looking to replace the oem mounts with something stiffer but don’t want solid mounts. I’ve been looking at the vibra technics and spoon mounts so far. Anyone have personal experience with either of these on a high hp s2000. The car is mostly street driven with the occasional visit to the drag strip for now but might spend more time at the strip than the street in the future.
Old May 29, 2019 | 04:11 AM
AP1Chief's Avatar
vibra technics are AWESOME!!!!
Old May 29, 2019 | 04:24 AM
mys2k3's Avatar
Which version are you running?
Old Jun 2, 2019 | 05:54 AM
spectacle's Avatar
Why? Stiffer mounts just break more shit. They hurt more than they help on this motor.
Old Jun 2, 2019 | 08:02 AM
outeiroj's Avatar
seconded... unless you want your teeth chattering this is the go to answer! probably one of the best purchases i've made for the vehicle
Old Jun 2, 2019 | 09:58 AM
spdracerut's Avatar
First time I've seen these. They look pretty interesting. My guess is the metal can eliminates the side-to-side movement the stock rubber mounts can do, but still have the relatively soft rubber to isolate the vibrations. I personally have the Hasport mounts in the street 62 durometer and I love them. BUT, I raised my idle speed to 950rpms to avoid heavy vibrations at idle. Without the raised idle speed, I would not tolerate them. With that fix though, they are great. They reduce the engine movement greatly and improved the shifter feel significantly.
Old Jun 2, 2019 | 10:10 AM
outeiroj's Avatar
correct i was barely able to install an etd with the vibratechnics already installed on the vehicle
Old Jun 2, 2019 | 11:10 AM
E4RTH WORM JIM's Avatar
Vibratec here too. Seem harsh at first but once they have bedded in they’re great.
Mine are the softer of the two options available HON200M
Old Jun 3, 2019 | 05:29 AM
mys2k3's Avatar
Just ordered a set of the 200m version the other day. Thanks everyone for the input.
Old Jun 3, 2019 | 09:41 AM
Kyle's Avatar
Good choice.
