high idle. what can it be ?
Old Feb 10, 2012 | 11:43 AM
S2KCHRIS305's Avatar
Default high idle. what can it be ?
hey guys so ive just installed my greddy kit a couple days ago. i was running pfab manifold, stock exhaust and ngk r567a-8 race sparkplugs went in for a tune and 232whp and 197trq at almost 9psi. very dissapointed with the tune i went to a different tuner that same day and he got me 257whp and 207trq, he couldnt really get more and told me something was wrong and that it was still underpowered . so he checked my motor , checked for boost leaks and everything was fine . motor seemed healthy . so he said it was the design of pfabs log mani . i went home that night he gave me a call when i got home and told me to change my plugs to ngk bkr8eix 2668 plugs . so the next morning i chaged my manifold back to the greddy one and swapped my plugs . when i started it up to drive to the tuner . i noticed my idle was high . was idling at 1600 rpms . drove to the tuner tried looking for vacumm leaks everything seemed fine , he did find that my AIC valve connector wasnt properly connected to the valve . he properly connected and it worked idle went back down to 900 rpms like stock . he tuned my car i got 270whp and 220trq at 7.5psi. i was pretty happy with the results considering that it was on pretty low boost and my S is completely stock ,stock map , stock cat and stock exhaust. right as we are unhooking the car to take it off the dyno . the idle goes back up to 1600. he said its my AIC valve giving out or to try giving it a clean . i got home and cleaned it as best i can and no change still high idle .so what you guys think it could be ?
Old Feb 10, 2012 | 02:28 PM
JoeyBalls's Avatar
TPS
Old Feb 10, 2012 | 02:37 PM
Tps. Throttle position sensor ?,I need a new one or can it.be fixed or cleaned?
Old Feb 10, 2012 | 03:29 PM
JoeyBalls's Avatar
a New one, there is a thread on here from S2Kart about it. Basically Honda wants to sell you a whole new TB, but its like $500.00. You can dremel the rivit on the TB to remove the tps, buy a new one from OMNI, buy a Voltmeter and install All for $60 and some patience. Try and find the thread, it's all explained
Old Feb 10, 2012 | 05:25 PM
Nyther's Avatar
270WHP on stock exhaust system on a mere 7.5 psi are outstanding results though. What flywheel hp are you? 320?
Old Feb 10, 2012 | 06:09 PM
How can I trouble shoot or find out more that its for sure my tps. Would like to know for sure its that befor I do the removal
Old Feb 10, 2012 | 06:11 PM
Im not sure what my flywheel number is. N il post up my dyno if you want
Old Feb 10, 2012 | 06:28 PM
JoeyBalls's Avatar
Use a Voltmete and see what your TPS is at IDLE, should be .45 or so, 4.75 full throttle, try and find the thread, it's all in there
Old Feb 10, 2012 | 08:20 PM
jaundice's Avatar
Check all of your vacuum hoses. Sounds like a vacuum leak. Thats exactly what your idle does with a vacuum hose off...
Old Feb 11, 2012 | 05:29 AM
sohc_mshue's Avatar
How high do you idle if you unplug the iacv?
