High mileage FI motor opinion
Old Mar 9, 2010 | 03:44 PM
vduber's Avatar
Default High mileage FI motor opinion
Ok so heres the deal it looks as if I am going to be getting a S soon, it has 145K miles drives fine. Eventually I know I will probably go with a s/c setup and I want to use it as a dd. These are my future options I see:
1. Bolt on s/c original motor til motor goes then replace
2. Swap out with a low mileage stocker (Im only planning on 400whp which I believe stock internals can handle)
3.Send out original motor to Laskey, have them work there magic.
Remember I want it to be reliable cause it will be my dd, I also believe that a properly built motor can be reliable if built by the right people such as laskey thats why I put that as one of my options. So what do you guys think any other ideas you guys have? Also if you think I should buy a lower mileage S please save the comment cause im getting a good deal on this one.
Old Mar 9, 2010 | 04:06 PM
DeadZero's Avatar
https://www.s2ki.com/search/forums?query=400+hp
Old Mar 9, 2010 | 04:16 PM
vduber's Avatar
Thanks for the Linky. Its not numbers im after basically what im looking for is 12 psi on a sos kit which will probably yeild me around 370 ish whp from what I have seen. So which one would you pick deadzero out of my 3 options?
Old Mar 9, 2010 | 04:35 PM
m R g S r's Avatar
boost the one thats in there. if it goes it's not going to just blow up into a million pieces. might lose compression over time and make less power.
pull that when the time comes and rebuild that.
Old Mar 9, 2010 | 04:36 PM
bluemetals2k's Avatar
run your stock motor with that mileage till something happens best thing you could do money wise...you never know that motor might take 50k miles of sc boost or 100k miles...HONDAS RUN FOREVER!!!! get an aem ems if you shooting for higher boost best thing you could do for engine longevity also.
Old Mar 9, 2010 | 04:55 PM
chef-j's Avatar
I will build at same time. That's just me.
Old Mar 9, 2010 | 05:02 PM
vduber's Avatar
yeah this is what i most likely was going to do. This will be my first honda for me so hopefully it will turn out well. I'll probably go k-pro for the simple fact of emissions since I live in ny but who knows cause the aem is cheaper.
Old Mar 9, 2010 | 05:08 PM
vduber's Avatar
[QUOTE=m R g S r,Mar 9 2010, 05:35 PM] if it goes it's not going to just blow up into a million pieces. might lose compression over time and make less power.
This made me chuckle a little yes I know my motor isnt going to explode into a million pieces unless i replace the cams with dynamite.
Old Mar 10, 2010 | 04:41 PM
TurboCongo's Avatar
Im tickin in at 107k right now! Mase engineering FTW! Mine is 400whp reliably and i DD mine too.
Old Mar 10, 2010 | 06:29 PM
vduber's Avatar
sweet stock block right? Hows that mase kit ive only heard great things about it?
