Hondata 4 bar map sensor and 14psi of boost?
Old Apr 13, 2012 | 11:03 AM
jsenclosure's Avatar
Default Hondata 4 bar map sensor and 14psi of boost?
Am i okay to use a 4 bar map sensor if i'm only going to see 14psi of boost max? I picked up a 4 bar but someone suggested to me i may want a 3 bar instead since i have lower boost
Old Apr 13, 2012 | 11:13 AM
miguel329's Avatar
Im using a 4bar with 14psi no issues.
Old Apr 13, 2012 | 11:15 AM
1SlowSi's Avatar
Theres nothing wrong going with a larger one so you don't have to upgrade again.
Old Apr 13, 2012 | 11:17 AM
DFWs2k's Avatar
Ill swap you. sos 3 bar, black. Barely used.
Sent using free Tapatalk - Android FTW
Old Apr 13, 2012 | 11:33 AM
Moddiction's Avatar
Former Sponsor
I'm running the Hondata 4 bar map sensor as well. I am at 12 psi and works great.
Old Apr 13, 2012 | 11:47 AM
DFWs2k's Avatar
I'll swap you and throw in a block off plate
Old Apr 13, 2012 | 12:14 PM
riceball777's Avatar
i'm useing a 4 bar map sensor and i'm only on 11 psi of boost on my pump gas tune
Old Apr 13, 2012 | 02:08 PM
05APdeuce's Avatar
Hondata 4 bar with 11 psi here. You will be just fine
Old Apr 13, 2012 | 06:46 PM
1SlowSi's Avatar
Haha lmao. You sound so desperate.
Old Apr 13, 2012 | 07:43 PM
DFWs2k's Avatar
i want a 4 bar. 28 psi isn't enough
