AN hose for Wastegate ?
Old May 5, 2013 | 05:44 PM
tx2K's Avatar
Default AN hose for Wastegate ?
Hey guys, how many of you are running AN hose for your wastegate lines? Is -4 okay for size? Ill only be doing mine for looks so Im just trying to put a list together right now of everything I will need. Also, did you use banjo to AN adapters on the wastegate ports or use straight metric to AN adapters? Feel free to post some pics if you have any. Thanks
Old May 5, 2013 | 06:36 PM
redboost10's Avatar
Get 10x1.0 to -3an adapter fittings and then use -3an line. No need for banjo fittings
Old May 5, 2013 | 08:59 PM
Dohntaut's Avatar
i used -4 line, worked fine for me.
Old May 6, 2013 | 05:45 AM
illestrolla's Avatar
1/8npt - -4an adapters
Premade -4an SS brake lines for my lines
Old May 6, 2013 | 06:04 AM
wy2slow_z's Avatar
-4 has worked for me as well.
Old May 6, 2013 | 07:54 AM
s2knoob89's Avatar
Using -3 lines for mine. You can use 1/8 npt fittings on the wastegate instead of 10x1.0
Old May 6, 2013 | 09:01 AM
tx2K's Avatar
Thanks guys. I guess either one will work, but there appears to be more options with -4 so I guess I'm going that route.
Old May 6, 2013 | 09:04 AM
redboost10's Avatar
It doesn't matter at all. -3 or -4. Metric or npt. Use whatever size is cheapest, haha.
Old May 6, 2013 | 09:09 AM
s2knoob89's Avatar
This
Old May 6, 2013 | 09:52 AM
passmans2kny's Avatar
the 1/8 npt really isnt the way to do it, i used it but get the metric to an ones instead
