How to check head gasket?
Old May 27, 2012 | 01:59 PM
cmn's Avatar
cmn
Default How to check head gasket?
I have fears that my head gasket is blown. The car doesn't use water, and the oil seems fine. No "mayonnaise" or anything under oil filler cap/valve cover or anything. But, as soon as I do some full throttle pulls the water temp rises rather quickly. I tried a couple of pulls on the last ride now to take a look at the water temp while doing this, and it seems the overflow tank filled up as well. Headgasket, or possibly air in the system? How can I find out the easiest way?
Old May 27, 2012 | 02:09 PM
ian02s2k's Avatar
Compression test, leak down test, oil analysis to see if there is coolant mixed in with it...
Old May 27, 2012 | 06:44 PM
o'malley_808's Avatar
What is your setup? (cooling, turbo, intercooler)
Old May 28, 2012 | 04:52 AM
cmn's Avatar
cmn
FullRace Prostreet/Stage 2. Garret GT3076R, FullRace intercooler. Stock cooling system until now, but just changed to Mishimoto triple core radiator. Still struggeling with air in the system...
Old May 28, 2012 | 05:11 AM
Did the car have the same cooling issues with the oem rad?
Old May 28, 2012 | 10:41 AM
s2klariat's Avatar
Compression test is normally a dead give away of a blown gasket. One or more of the cylinders will have significantly lower numbers.
Old May 28, 2012 | 03:04 PM
Competitor9's Avatar
Try a leak down test and take the rad cap off if the head gasket is blown you'll get air bubbles in the rad.
Old May 28, 2012 | 11:15 PM
03supers2k's Avatar
My water temp gauge was acting silly, my coolant tank was fluctuating too much, and my heater was acting funny I knew my headgasket was going out, so I replaced it last week now everything is perfect. I didn't even check compression just do it. I went 2.5 years 20,000 miles on my headgasket I'm happy with that
Old May 28, 2012 | 11:32 PM
redap186's Avatar
was it a inlinepro 3mm???? and how much psi were u pushing?????
Old May 29, 2012 | 04:15 AM
bac7213's Avatar
Banned
seems like head studs streched....deck head,,,new oem gasket and fullblown head studs....and youll be good
