How did u guys install your log manifold/turbo
Hey guys I have the speedcraft kit. pretty much the same setup at the manifold/turbo/wg part as UR or inlinepro. I'm trying to put all 3 in at the same time, and it's not fitting. My friend bent his a/c lines before putting all 3 in at the same time but i'm not able to do that. How did you guys put yours in? did you slide it in from the bottom or did you have to put them in separately? I want to keep at least the turbo/manifold together since it is really hard to get to some of the bolts once it's on. Any help is appreciated. Thanks!
Steven
Steven
I did my manifold and turbo together install when I had the UR kit but didn't have the WG on. I pulled the VTEC oil pressure switch off that sticks off the engine and just kinda positioned the setup in different orientations from the front of the engine and just kept trying until I finally got it in.
Originally Posted by SoCalIsMyLife,Jun 14 2007, 12:13 PM
pulling the vtec pressure switch might help. anything i have to watch out for? should just bolt on and off right?
BTW, if you're using an AEM EMS, you can remove this oil pressure switch permanently and put a bolt in it's place.
i was actually taking about the vtec swtich. but i took that off and the wastegate off, and it went on without any problems. thanks guys! Now, if I'm temporarily using the Vortech FMU w/ my turbo until i save up enough for a EMS, what should i connect the vacuum hoses on the FMU to? the manifold like the manual says or to my boost reference?
Originally Posted by PeanutButter,Jun 14 2007, 10:28 AM
Unbolt the motor mount
Lift motor up with jack 3 inches
Put in manifold and turbo
Lower motor
Re bolt motor mount
Lower motor
Re bolt motor mount
