How does my timing look? after 3mm ILP install
Even with the timing marks like tha ti could be 180 degrees out?
So what should i do? take the spark plugs out. turn it to TDC on cyl#1. And look in? What am I looking for?
I'm not too sure if it will stop spark but spark timing will definitely be off.
As you have it in that picture, look down through the spark plug holes on pistons 1 and 4 to make sure they are at the top of the stroke. Its too hard to tell in the pic if your marks are all lined up and if pistons 1 and 4 are at the top.
i was having problems with my cam timing as well. maybe this thread can help u!
https://www.s2ki.com/forums/index.ph...ic=543034&st=0
good luck!
good luck!
to the op
that looks correct, so long as cylinder one is at TDC.
the marks on the idler gear are offset so if they line up w/the top of the head and cylinder 1 is at tdc you cant be 180 out.
and you cant really be 180 out on a 180deg 4 cylinder either way, as long as cylinder 1 is at tdc and the marks on the cam gears line up you're good.
Originally Posted by Bigeggroll,Nov 6 2009, 11:48 PM
indeed a very good question!
