How to 'idiot-proof' my EMS?
Before the flaming begins over this, I've already sent out a couple PMs to some people but haven't received a response back, and I've looked around on the forums, to no avail.
Sadly, roughly 48 hrs after driving my newly turbo'd AP2 back from Inline Pro's shop in VA to my home in north central FL, I was backed into by a lady not paying attention to where she was going. I love my luck in life. Anyway, having said that, it's obvious that I have to drop my car off at a body shop to get the driver's side door fixed and repainted where she stripped the paint and left a 1/4" wide gash the entire length of the door. My problem is that there's no way in hell I'm just leaving my car as is with anyone with the power its making.
Is there a way to make a 'valet' mode or anything with the AEM EMS without getting too far as to screw the tune up? Can I just lower the rev limiter to say 3500-4000 rpms or will that screw other things up?
Simple question, I know, but this is the first time I've run into this problem. Any helpful suggestions from the F/I crowd would help. Thanks.
Originally Posted by djdorifto,Jun 16 2007, 01:14 PM
I don't know why they would need to drive your car in the first place... Put it in Neutral and push the car around the shop...
That being said, I'm not risking this on my 400whp AP2, it's just not happening.
My question on boost cut and changing rev limiter, is it really as simple as just going in and changing my rev limiter from 8500 where it is now to say, 4000? Then when I get it back I can change it to 8500 again without that affecting ANYTHING ELSE in the program?
My fear is, as I haven't worked with a standalone before, that if I change something as simple as the rev limiter or psi where boost/fuel is cut and save those settings, that when I go to change them back to how they were, it will have screwed up the other more important and intricate settings that there's no way in hell I'll be able to reproduce unless I drive to Tampa and get another tune.
Originally Posted by FurY,Jun 16 2007, 02:30 PM
Sorry about your luck man
How's the car running otherwise? Which turbo did you go with?
Although many people run the 3076R cartridge, I can pretty much say that I am the only one with this turbo, unless someone else out there wants to prove me otherwise. No notching of the frame required either
My only complaint is that I have yet to receive a dyno chart for it.
The 6 puck takes some getting used to, but I've grown used to it by now, its a chattery sob at stops, but damn does it grip.
Originally Posted by Spec_Ops2087,Jun 16 2007, 03:18 PM
Yes its as simple as that; gotta to love the AEM system.
I can't get in touch with anyone else, so this is my last resort, but thanks for the info.Tim - why would it hurt anything if they run the car @ 3500-4k miles for a few miles?
Pm minitoyota he's actually pretty good with the aem system, he's always on his laptop.
I believe you can change whatever you want on the map and after you get your car back you can load your Original Map on your car and it will be back to normal.
Marcus
Marcus
Marcus
Marcus
