How to install stock FPR
Hey guys,
I have a Comptech SC but I want to get rid of the Comptech FPR because I am tuning with the EMS from now on. I was wondering if someone could explain how to reinstall the stock FPR. All help appreciated! Best, J |
it is attached to the fuel rail via two small bolts (not sure what size) there is a vacuum line going from the "top" of the fpr to the intake manifold, and i think the fuel return line attaches to the other side of the fpr
the fpr has two lines on it, top small tube is on a bent tube and is for intake pressure, bottom line is larger and goes straight down and is for return fuel. I believe the nuts are 10mm. There is also a rubber o-ring that goes into the FPR to prevent gas leak.
Above post is correct, it attaches to the fuel rail |
Anyone got a pic so I can get a better idea of the bolts I need to buy and stuff? I just got the stock FPR.
Thanks guys... |
Don't need to buy any new bolts its super simple just unbolt the 2-10MM bolts and take off the two lines one for vaccum one for fuel return. To put the stock on just reverse make sure the rubber o-ring connecting the fpr to the fuel rail is still intact.
Alright, I'll give this a go today. You're making it sound easy enough.
I'm getting ready to do the same.
A little late but here's my before and after... https://cimg5.ibsrv.net/gimg/www.s2k...4bcb83384a.jpg https://cimg6.ibsrv.net/gimg/www.s2k...f3d90468ce.jpg |
