How Loud Is Turbo S2000
I Live In California So I Have To Comply With The 95db Sound Level Garbage, I Recently Bought And Installed An Invidia N1 Exhaust, And It Was WAY Loud As I Expected, So I Put A Resonator On It And That Will Keep Me From Being Pulled Over For Now, When I Get My Greddy Turbo Kit, If Im Running The Same Exhaust But I REMOVE The Resonator, Does Anyone Know About How Much The Turbo Would Quiet Down The Exhaust Note? Because I Really Dont Want That Restrictive Resonator On There When I Go Turbo.
If your existing resonator isn't a 3inch, switch it out for this one: http://vibrantperformance.com/catalog/prod...products_id=293
Less than $100
Less than $100
Do some research tho because opening up your exhaust too much may cause creep.... I would say that removing the resonator with your current exhaust should be ok for noise level since ( as you stated) the DB level of turbo cars is muffled by the turbo...
