How many boosted miles?
Old Aug 12, 2011 | 09:04 AM
Drkphnx's Avatar
Default How many boosted miles?
Just wondering how many miles you guys have gone on a single set up with no issues, Post up your set up, how many miles and how much power. You can post supporting mods if you want.
Comptech Supercharged non A/C (novi 1000)
300rwhp @ 7lbs
60k miles, Zero issues
Old Aug 12, 2011 | 09:16 AM
james0933's Avatar
I feel like I'm in the FI section way too much now.
600 miles
300+ hp @6-7 psi
Ct novi 1000/ UR INtercooler
I had a belt issue, but it just ended up being a loose mount. The ct FPR was making a weird pulsing noise, but went away for the most part after putting the black injector cover back on. My damper pulley was tapped wrong and I had to have it redone. Right now I'm getting a weird Vibration type noise at 3-3.3k. I'm sure it's a pipe rubbing against something...easy.
Of course these are all just little bugs that happen when you first put it on. I'm pretty satisfied.
Old Aug 12, 2011 | 09:35 AM
DFWs2k's Avatar
i thought siadam had a similar thread already?
inlinepro stage 2 turbo kit, ~15 psi = 450whp/288wtq
20k+ miles, oil leak from terrible oil return (finally fixed), popped a driver's side axle over a year ago (was in the process of doing a burnout), wastegate lines popped off before I knew to ziptie them (boost cut FTW), chargepipe came off (really easy to notice)
nothing serious, try to do everything well the first time, and then fix the little problems and you will have trouble free operation
Old Aug 12, 2011 | 09:54 AM
sata3000's Avatar
Ptuning GT30/76 Turbo 14psi 435whp 304lbs tq Stock internals stock head gasket
3000miles no issues
Old Aug 12, 2011 | 11:53 AM
Corey Maurer's Avatar
500WHP about 1500 miles so far.. cracked a manifold cuz i was a dumby and didnt use a flex pipe, otherwise issue free
Old Aug 12, 2011 | 12:47 PM
azride1983's Avatar
KW high boost 355whp/255wtq 11k miles 0 issues so far.
Old Aug 12, 2011 | 03:18 PM
camuman's Avatar
roots blown 344/245 10k miles, driven hard, no issues that i didnt cause, ie ported blower led to one failure, but was fixed.
1200 miles 450whp. then dump tubes broke off and i fragged a wire. not a big deal, happens lol.
Old Aug 12, 2011 | 05:17 PM
steven975's Avatar
About 3K, no issues.
Well, other than snapping a bung on the vacuum tank when fiddling with the vac lines to add a boost gauge; the line snagged in the pulleys. $15 fix tho.
Old Aug 12, 2011 | 07:55 PM
penguinsintuxedos!?'s Avatar
My previous set up:
InlinePRO stage 2 @ 19psi 546whp/480tq
20k miles with only minor heat problems and my oil filter relocation bracket broke once. The car was driven hard, to multiple states, and i hit a deer about 1000 miles before i started my new build, unknowingly driving around with a cracked radiator
Old Aug 12, 2011 | 08:04 PM
Moddiction's Avatar
Former Sponsor
Vortech supercharged. About 30k miles now I think. I have 149k on my car now. 1 year at 7 psi and running super lean regularly. Since march now at 400+whp on 12 psi.
I am having some engine oil consumption recently however. Valve stem seals seem to be leaking and possibly rings a little bit since it smokes WOT a bunch and when idling from valve stem seals. Pulls great still and makes boost the same.
