How much fuel psi from fuel line?
Old Mar 21, 2013 | 07:05 AM
lopez14's Avatar
Default How much fuel psi from fuel line?
What's the psi for our cars in the fuel delivery line before getting to the rail. I have an extra fuel line tapped into the fuel delivery line, what psi does that extra line have going through it? Does the psi lower as I give it gas and the engine uses more gas or is it always constant?
Old Mar 21, 2013 | 07:11 AM
herecomesboost's Avatar
Fuel pressure is 43.5psi. Are you using the stock FPR? What do you have tapped into the feed line?
Old Mar 21, 2013 | 07:38 AM
lopez14's Avatar
Yessir stock fuel pump, rail, regulator. So it's 43.5? And that's a constant 43 even if fuel is being used out of both fuel lines? And it's tapped for a fuel solenoid on a nitrous kit
Old Mar 21, 2013 | 07:40 AM
sohc_mshue's Avatar
The regulator will try to keep fuel pressure constant as long as their is enough flow from the pump the meet the flow demands of the engine.
Old Mar 21, 2013 | 07:54 AM
You could see an appreciable pressure drop if your second solenoid is using a jet that is too large for the stock fuel system to support.
Old Mar 21, 2013 | 08:00 AM
lopez14's Avatar
It's only a 75 shot so I should be fine, I'm shooting for 41 nitrous and 24 fuel does that seem about right?
equ117
Mar 15, 2019 01:03 PM
MugenAP2
May 20, 2008 01:16 PM
mrfast32
Apr 3, 2008 04:49 PM
GDM S2K
Mar 15, 2006 01:56 PM
