how much HP will i make?
just wondering what hp#'s i can expect from my set up as i have never boosted a f20c
2.4l stroker kit
9:1 comp
1ml headgasket
1000 cc injectors
dart sleeves
Hypertune Intake manifold
Pfabs top mount tubular manifold
garette gt35-r
hsk turbo air horn
24x12x4 intercooler
3" turbo piping
100 mm thottle body
turbo smart progate 48mm
turbo smart blowoff
3" custom downpipe
bc valves
bc valve seats
bc dual springs
bc tit retainers
slitgh portmatch on head
oem cams
aem ems aem map sensor
magna guel 750 external pump and filter
custome braided fuel lines
aem fuel rail
Elite Performanace oil cooler kit and oil filter relocation kit
koyo rad
inline rear end kit (next spring)
that is my motor set up should be done pretty soon build pics will be up as the car gets put together
any custom work other then the manifold was done by me and Albert from One Touch Tech
wish me luck
2.4l stroker kit
9:1 comp
1ml headgasket
1000 cc injectors
dart sleeves
garette gt35-r
hsk turbo air horn
24x12x4 intercooler
3" turbo piping
100 mm thottle body
turbo smart blowoff
3" custom downpipe
bc valves
bc valve seats
bc dual springs
bc tit retainers
oem cams
aem fuel rail
koyo rad
wish me luck
Kinda hard to give an estimate considering there aren't any boosted 2.4s on the boards... I would definately go with a larger turbine though, considering you'll already have a low end grunt from the increased bore...
bigger Turbo and screw spool time!
