How to prime turbo
Old Jun 22, 2010 | 06:28 AM
Envied's Avatar
Default How to prime turbo
Ok, so I am going to be receiving my turbo back from Precision. They found that the bearings were scorn pretty bad, possibly from contaminated oil? I have checked everything out and have no signs of contamination in the oil. I also let it idle down for a bit before shutting down. I never primed that turbo, nor the Greddy when I installed it.
With all that said, I want to start off right this time around. So how do you prime these turbos?
Old Jun 22, 2010 | 06:39 AM
vader1's Avatar
Old Jun 22, 2010 | 06:40 AM
Suzuka_Joe's Avatar
Wasn't aware you do. Maybe unhook the cam sensor and crank it a couple times
Old Jun 22, 2010 | 06:41 AM
camuman's Avatar
doesnt it prime when you prime the oil system. turn the crank with a 1/2inch drive or a crank pulley tool. oil pump spins wiht the motor, so manually turning the motor will cuase oil to flow.
dry fireing the motor i dont beleive is the best way to do this.
Old Jun 22, 2010 | 07:01 AM
siadam's Avatar
I pull my fuel pump fuse under the dash (drivers side).
Crank the motor over 6-8times, put it back in, fire her up.
Or if your anal, take a small abount and pour into the turbo feed to get it coated, spin the impeller and connect it all up, fire her up and do work.
Old Jun 22, 2010 | 07:50 AM
wadzii's Avatar
Banned
take the spark plugs out, unplug the cam sensors and turn the engine over till the oil light goes off.. same as priming the oil system with a new motor.
the engine wont build up any oil pressure unless you take the plugs out, the starter can spin it over much faster w/the plugs out.
Old Jun 22, 2010 | 07:55 AM
camuman's Avatar
NM there ya go. makes sense now that i think of it. when i was writing it i was remembering when i did my brand new motor turbo in the hatch. that time i wouldnt dry fire a motor.
but if the motor is not new, nothing wrong with doing it to get some oil up in the turbo.
<-------FAIL.
Old Jun 22, 2010 | 10:34 AM
EngineerX's Avatar
Yep - that's 2 of the better ways to prime the turbo.
If you're paranoid about it you can also have the turbo oil outlet hose discharge into a clear water bottle and if you see oil pouring into it, it's primed!
Old Jun 22, 2010 | 10:43 AM
DFWs2k's Avatar
what happens if you don't prime the turbo? seals go bad quickly?
Old Jun 22, 2010 | 11:36 AM
D1sclaimer's Avatar
I was planning on just turning off my injectors through my EMS to prime my turbo.
