HOW-TO: Wiring Hondata Boost Solenoid
Thanks for your link in the other thread, but im running the Aem ems, will it still work using those two wires you mentioned above? I dont have a connector D to plug into the ecu, so id rather run it this way.
The only reason for hooking it up to this wire is because its a SWITCHED GROUND rather than constant. Regardless, 1 wire will go into a switched +12v and the other wire goes to the switched ground (purge wire). It doesnt matter which of the 2 wires you use so don't about trying to trace which one went to what.
