HP/torque #'s with S/C and other components
i was just wondering what's your HP/torque with Comptech S/C, IHE, etc... done. RWHP if you have it. can you have it a little over 400 crank, say 420-450?
tnx
tnx
Originally Posted by OyATL,Jul 27 2005, 12:33 PM
350/200 with just an exhaust. I guess its about 400 to the crank.
In fact, I'd be interested in what fuel pressure you have to run to get those 550's to do the job.
tnx
tnx
Originally Posted by FF2Skip,Jul 27 2005, 12:44 PM
I wouldn't discount the EMS and larger injectors, 'cause you ain't getting 350 w/o 'em!
In fact, I'd be interested in what fuel pressure you have to run to get those 550's to do the job.The gauge on my fpr reads 40psi at idle.
Originally Posted by FF2Skip,Jul 27 2005, 12:48 PM
Which dyno you get that on matters a bunch, too.
), they are really close. And when you are figuring crank hp...it's around 15-18% higher than dynojet numbers...not dynopak numbers.Edit: Nevermind I though he was running a vortech...a comptech running 10psi will net larger gains than a vortech at the same boost level. Dems' really good numbers OyATL
Boost is boost. How can the one supercharger make more power than the other if the only thing that counts is boost??? Nobody has measured the power necessary to run the snail. Please enlighten us.
