I NEED A THE GREDDY BASE MAP!
Old Nov 2, 2007 | 11:42 PM
brilliant's Avatar
Default I NEED A THE GREDDY BASE MAP!
hey guys, so as you know, my tune that came with my greddy kit was incorrect. I had the same problem a couple other guys had with the 7k redline and incorrect a/f. Well another member sent me a map he said worked and installed it on my car and it is NOT running well, way too rich at idle. Anyways, I desperately need the ap1 base map if anyone has it!
--David
Old Nov 3, 2007 | 06:57 AM
ChefJ's Avatar
go to the tuner.
or if yo uhave some knowledge, pull some fuel at idle.
Old Nov 3, 2007 | 10:41 AM
brilliant's Avatar
i don't have knowledge and it isnt driveable.
Old Nov 3, 2007 | 11:12 AM
S2Kart's Avatar
Karno sent me two, which I will send you.
File 1: uses airflow pressure voltage for injector adjustments
File 2: uses throttle position % for injector adjust, and pulls slightly less timing from 6000 to 8500rpm.
All other parameter in both files are the same.
I believe File 1 is the standard base map. I suggest using it, since pressure V injector adjust is the norm. Karno is using file 2 with success though, and you can see where he pulled less timing and gained some extra HP.
PM me with your email address
Old Aug 7, 2008 | 01:08 PM
lucky77's Avatar
Having some issues with my Kpro so have got hold of an ULT to try. Unfortunately i dont have the original base map and i dont know any one else here in the UK to get the base map of.
Can any one email me a copy?
Thanks
Old Aug 7, 2008 | 01:14 PM
Revenge's Avatar
I do but it's on my work computer I can send it to you on Friday.
Old Aug 7, 2008 | 01:18 PM
lucky77's Avatar
Thanks mate,
Ill PM you my email
Old Aug 7, 2008 | 02:48 PM
S2SEXY's Avatar
for the hell of it can you guys send me the files too
Old Aug 7, 2008 | 10:42 PM
Artisan7471's Avatar
Yea ditto I want some Emanage ultimate maps too!
Old Aug 8, 2008 | 08:08 AM
03silver2000's Avatar
Can someone send me a aem ems1052uego base map, I cant start my car with the one I have now and IP need it to drive it aorund to break everything in and mmake sure theres no leaks.
Jordan
