i need help with running oil lines an coolant
Old Jul 8, 2009 | 05:36 PM
keefss2k's Avatar
Default i need help with running oil lines an coolant
ok guys im putting together my turbo setuo for my car and im going with a gt3076r turbo with a pfab top mount manifold. so where will my oil feed and oil return line go? i was told i had to tap the oil pan for the return line is that right? so what about the feed wheres it come from? an i need help with the coolant as well. thanks and pics and diagrams would be alot of help so i can get my turbo set up going do i need sandwhich adapter or a relocate kit or what? pm me or post on here thanks guys
Old Jul 8, 2009 | 10:30 PM
chad86's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry14856742
this might help you out...
Old Jul 10, 2009 | 12:12 AM
misz's Avatar
I run the GT30 and the pfab top mount manifold. I take the oil from the stock oil pressure sensor with a fitting from Tuner Toys. (http://www.tunertoys.com/TunerToys_O...et_p/otodk.htm). I still run the stock oil pressure sensor on that fitting. For the oil return i run a -10 AN line into a welded AN -10 nipple in the girdle.
Water lines are connected from the front hard line one the engine and routed to the stock oilcooler/warmer.
Old Jul 10, 2009 | 05:51 PM
keefss2k's Avatar
got any pics of ur car with that turbo hooked up?
k00leo
Dec 29, 2013 07:19 AM
pkolaboy
Nov 14, 2011 09:48 PM
Ilike2DRIFT
Aug 24, 2010 10:12 AM
hondabim
Sep 15, 2008 12:17 AM
