I need your imput on A/F ratios
Just installed my wideband. From what I can see is at idle I'm at 10.5. At WOT around 6-8k RPM Im hitting 16.5 A/F. Is this something that should be addressed?I'll try and get a video uploaded when I get home.
10.5 is way too rich for WOT. and 16.5afr is way to lean for idle/cruising, let alone WOT. Either you are having a problem with your wideband, or who ever tuned your car needs to get back on it right away! Lousy.
You should be at 11.5-12.5 WOT 14.5-15.5 idle/cruising
idle should be as lean as it will go and the idle be stable
cruise should be as lean is it will go and still be smooth and drivable
wot is usually around 11-12:1 on a turbo car, 12-13:1 on an NA car
