I want boost.
Old May 23, 2011 | 07:35 PM
Sm000th's Avatar
Default I want boost.
Hey all!
I recently have finished my car cosmetically as I have wanted, and I am looking to go boost. I am not looking to get into heavy duty tracking but I want both the aspect of having a turbo kit for the sake of accomplishment, and the ability to know that I have the power (but rarely ever use it)
I want to ask the s2ki community a few questions (I checked the FAQ and didnt find anything and I want to ask other people that own s2000's since other cars that my friends own may be different)..
-My car is a bit beyond the 100k mile mark, is this a problem?
--If this is a problem is there anything outside an engine swap (to a newer engine) I could do?
I'm looking at (and interested in) the PTuning kit, would you say this is a good kit for moderate power and
minimal maintenance needs? (I hear horror story's of peoples Turbos constantly acting up)
- Should I look to do anything to upgrade my engine itself before turboing? Or is a stock block acceptable?
Any other things I should think about that I am not necessarily thinking about would be necessary, especially if they are pertinent to the PTuning kit!
Thanks!
Old May 23, 2011 | 08:07 PM
passmans2kny's Avatar
the p tuning kit is great and is prob the most complete kit out there, i would do a compression and leak down test to see the health of the motor, if all cylinders check out boost that bitch
Old May 23, 2011 | 08:51 PM
DFWs2k's Avatar
what year is your car/engine
Old May 23, 2011 | 09:14 PM
Sm000th's Avatar
Imma AP1 2000
Old May 23, 2011 | 09:20 PM
DFWs2k's Avatar
to be safe, you'll want to upgrade your oil jet/banjo bolts, and the retainers
Old May 24, 2011 | 04:31 AM
Revenge's Avatar
The ability to have the power and not use it....then get a Super charger.. You need to get a clutch alonge with the other things listed in this tread. Just make sure you have close to 10k to put toward you whole change over to a turbo. A SC would be a bit less expensive and more reliable for your older car. The ptuning kit is the best turbo kit however IMO
Old May 24, 2011 | 06:09 AM
JoeyBalls's Avatar
PFAB
Old May 24, 2011 | 06:29 AM
Torque Obsessed's Avatar
Once you have boost, you WILL use it. Especially something awesome like the Ptuning setup.
Old May 24, 2011 | 07:25 AM
kels_2k's Avatar
agree pfab stage 1 kit,I also had luck with my inlinepro stage 1. my kit is a great turbo for autox, quick spool
since I dont track I now went Pfab stage 2
Old May 24, 2011 | 07:49 AM
Sm000th's Avatar
I know its going to be expensive... The whole transition to turbo is going to be this winters big project... I already knew I'd need a new clutch (My clutch is pretty shot anywho so regardless of turboing my car or not I'd have to change it)
And I have heard from multiple people from the forums that if your going to turbo that you should expect to spend $10,000...
I guess my reason for starting this thread was to see if I was stupid to turbo such a high mileage s2000.. and if Im not completely stupid, what I'd have to do to my car to prep it to handle the turbo.. so far Ive got:
Clutch
Oil jet/banjo bolts & retainer
I understand that a SC is alot more reliable.. But I also dont like how the power that comes from a SC is very gradual, and not quite the same feel as a turbo..
