IAT Sensor after boost
Old Jun 24, 2012 | 05:00 PM
aitrus16's Avatar
Default IAT Sensor after boost
Ok so I have a quick question about IAT sensors. I am running a 2006 DBW boosted s2000 and I originally had the sensor before the turbo but it does not seem to be as accurate as it could be.
I talked to the tuner and I am going to relocate it just before the throttle body.
Anyhow here is the question, my sensor is not air tight as it goes into a grommet normally in the airbox, looks like this...
So when I relocate the sensor I am assume it needs to be airtight, has anyone had to replace this sensor and if so what did you use.
Input is always good, been trying to search the board but its a hard topic it seems.
I did find that people report some sensors have a different temperature scale and as I am using flashpro I don’t think there is a correction table.
Any help would be appreciated
Thanks
Old Jun 24, 2012 | 06:30 PM
japhethwar's Avatar
You can buy a bung from kraftwerks to weld on your charge pipe, make a custom one, use a tight fitting rubber grommet if your keeping the boost low, or switch to a threaded iat. The simplest is probably the kraftwerks bung, or a rubber grommet.
Old Jun 25, 2012 | 09:23 AM
redboost10's Avatar
get a bung and a good iat sensor...www.t1racedevelopment.com, has nice ones
Old Jun 25, 2012 | 09:30 AM
s2konroids's Avatar
Is it worth relocating the IAT on an SC application running a greddy emanage ultimate? - power wise, obviously i rely on stock IAT corrections since its a piggyback.
Old Jun 25, 2012 | 09:36 AM
BrockB's Avatar
I am selling the t1 iat sensor WITH the bung on my for sale page in the link where my signature is if youre interested
Old Jun 25, 2012 | 10:02 AM
aitrus16's Avatar
I just called up Kraftwerk and talked to Brian, got one coming will post pics after
Old Jul 18, 2012 | 12:17 PM
aitrus16's Avatar
Here is a Pic, sorry for the delay.
So basically this came in aluminum.. to bad my piping for intake is steel.. Ok so bout a pipe adapter and some hose got it done.. Worth every penny.. Hot side 140F cold site 90F.. it was a very hot day..
staylor725
Nov 2, 2014 03:30 AM
HankookS2K
Oct 9, 2014 05:39 AM
sky-chicken
Apr 6, 2003 09:54 AM
