IAT sensor - is it a true representation of intake temp?
That's what the sensor looks like when the outer plastic is removed.
I'm going to do a full write up on moving the IAT sensor from the IM to the charge piping. I don't know when, but I will. In short, the results are very positive and worth the effort.
The IAT in the manifold becomes heat soaked from the very manifold it is mounted in during low flow situations. When trying to use IAT comp, if you try pulling some fuel as the temps go up, you can find your car barely idling between AutoX runs when you have a co-driver running back-to-back. BTDT.
Honda moving the sensor to the rubber intake hose was a good move.
Has anyone with an 06+ thought of mounting the IAT sensor in the air pump port of the aftercooler? I think that would be the location with the most realistic intake temperature and shouldn't get heat soaked due to the coolant running through the aftecooler. I was debating doing this when I finally get my build done.
I would put a threaded 1/8 NPT bung and weld it to the aftercooler outlet.
Here's a RSX IAT sensor placed in a NPT fitting using epoxy
Taken from https://www.s2ki.com/s2000/topic/906...t__p__21817077
Well its a pretty simple experiment to see if the AIT sensor is working properly, just read the temp with the car cold that has been siting for 24 hours. If it reads ambient then most likely it is working properly. Moving your sensor can be a bad idea. Any length of piping that air flows through will conduct heat to the charge air, especially aluminum pipe. The reason Honda could move the AIT without affecting the reading, is that the stock intake is plastic. Plastic has a very low thermal conductivity. You want to tune for the air temp as it enters the cylinder, this gives the ecu the best approximation of actual AIT.
Most people miss the point of AIT numbers. Unless you are drawing air from outside the engine bay completely, your radiator has more to do with Ait,s than anything else. A radiator is essentially a air heater, your intake takes in air that has gone through the radiator! If your AIT sensor says that your intake temp is ambient, that would be more of an indicator of a broken sensor than +20 over ambient.
