ID 1000's and E85?
Old Nov 4, 2009 | 04:48 PM
  #31
sbrodacz's Avatar
Banned
4 1000cc injectors running e85 would be good for around 500 at the wheels.
On 93 they should make about 660 maxed out, so since e85 takes about 25-30% more volume than gas that brings you to around 500.
and wow that integra. That thing is idling rich as hell and definitely needs new motor mounts hahaha
You should real read through the post before commenting. I hate when people do this! There already is a member on here who made 620hp with e85 on 4 1000cc injectors and the injectors are only at 90% duty cycle.
Old Nov 4, 2009 | 04:54 PM
  #32
Spoolin's Avatar
E85 A/F is run at around 12.5:1-12.8:1 on boosted applications as apposed to 11.5:1-11.8:1 with gas or race fuel. Meaning you can run it quite a bit leaner.
Old Nov 4, 2009 | 06:54 PM
  #33
wadzii's Avatar
Banned
the air fuels you quote are for gas.. stoich for e85 is 9.7:1.
if you use a standard air fuel gauge that displays gas afr's you would want to shoot for around 10.5:1-11:1, thats 0.7ish lambda
for an NA car, around 12.5 or so is what you would look for
Old Nov 4, 2009 | 08:56 PM
  #34
Spoolin's Avatar
Not according to the big EVO guys that make big power on e85. They, along with my friend/tuner that has an 800 whp AMS built EVO runs his at 12.5:1 A/F reading off his wideband and I've seen it first hand.
Old Nov 5, 2009 | 04:49 AM
  #35
wadzii's Avatar
Banned
then the blend they use must not be e85. i have tuned alot of cars with all sorts of fuels and gas is almost always the "leanest"
those 800hp t3 turbo'd evo's dont really follow the "rules" anyway.. lol
alot of e85 is really e70, which you could probably get away with running that lean.
Old Nov 5, 2009 | 11:14 AM
  #36
STL2SLW's Avatar
This is True at red line i am at 12.5 afr and right around 12 every where else. E85 is run leaner then gas.
"Is that 90 psi of fuel pressure at full boost? Can you tell us what you have your idle fuel pressure set at?" I would have to double check this but yes i believe at red line or at least close but like i said not 100% sure. The car is in storage now so i will not be able to get to it. I will talk to my tuner and see if he remembers.
I also never added The injectors are maxed out at this level I will be going to the ID2000cc ones next year and see how much they are good for.
Also Remember peter at ISP has made 730whp on E85 Twin walbro's and 1600cc's on a 6262.
Old Nov 5, 2009 | 11:31 AM
  #37
Spoolin's Avatar
Thanks for confirming that man. I knew you could run e85 leaner.
As for the ID2200's, ill be going with those in the near future also. I'm just going to wait a bit to see if the price of them drops and go ahead for now and max out my rc1000's at a higher fuel pressure like you did. I hope to get around 600 whp out of them. That will be great if you can get that info as to where you have your idle fuel pressure set at. Ill be installing the FB dual pump setup in about a week so ill have plenty of fuel flow for this.
Old Nov 5, 2009 | 05:05 PM
  #38
Shftat9k's Avatar
STL2SLW what boost levels did it take to achieve those numbers?
Old Nov 5, 2009 | 09:58 PM
  #39
STL2SLW's Avatar
I am running right around 21-21.5 psi at full boost.
Old Jul 24, 2017 | 04:34 PM
  #40
nguyen365's Avatar
I know this is an old thread but spoolin how many whp did u put down? I'm getting my setup returned this Wednesday single fbm 340 pump Id1000 e85.
