ID 1600 injectors
Old Sep 8, 2012 | 08:39 AM
D1sclaimer's Avatar
ID2000 injectors are well worth the cash. They are my recommendation.
Old Sep 8, 2012 | 08:46 AM
JoeyBalls's Avatar
do the 2000's work with race gas?
Old Sep 8, 2012 | 08:54 AM
jpetch05's Avatar
For the record. It's a Bosch based injector with a star pattern ground tip. If you have Bosch, grind the tip, and flow them on a bench and flow match them. They're the same damn injector.
Old Sep 8, 2012 | 08:55 AM
jpetch05's Avatar
On multiple cars we have compared them to the ID and they both run flawless.
Old Sep 8, 2012 | 09:19 AM
camuman's Avatar
i run the bosch 900 or 1000, whatever the hell its called. its fine.
i want bigger lol. pm me with details. i might be stepping up.
Old Sep 8, 2012 | 09:33 AM
passmans2kny's Avatar
so if i just flowbenched my bosch ngi-2 2000 or 2200 injectors I could get an idle like the id2000s? like under 1000 rpms? whats this about grounding down the tip?
Old Sep 8, 2012 | 10:30 AM
jpetch05's Avatar
By grinding the Bosch 900 you can make them ID 1000's. The 1000 is a 900 injector ground down. We make 1300's by grinding 1100's
Basically ID injectors grinds the tip down so that they flow more then the traditional bosch. They just do it in a fancy star pattern which is not necessary. (and we have taken apart ID and FIC and Bosch injectors) they all are then damn same. We flow them twice and make sure the sets match. All of which are a Bosch based injector once again.
As for the Bosch 2200's we do not modify them cause there is no need. But yes. We grind them. Clean them. Flow match them and everything. If anyone is interested. We are getting a big order soon. We also have top hats and things. Usually the cheapest you can find for them is about 650 bucks. Let me know so I can hook you up with a much lower price if you guys want some. If I get enough people who want them I can order more. But there is a minimum order number I need to have to get the discount.
Old Sep 8, 2012 | 10:36 AM
jpetch05's Avatar
I have friends running our modified Bosch 1100's and they have made 600+ for over a year now without any hiccups.
And we are looking into getting the new "supposedly" 1600's because like I said the old ones had many issues especially with pump gas
We just got 5 trial ones in. So. I guess we need to find a dummy car haha
Old Sep 8, 2012 | 10:55 AM
where are you located? I might be interested in you matching my injectors on the flowbench
Old Sep 8, 2012 | 11:32 AM
jpetch05's Avatar
Northeast Ohio
