id1000 injectors need spacers?
i bought some id1000's and didn't get spacers with them. friend of mine has some and he got spacers with them. Do i need them? call T1 and just get them from those guys i guess?
the car my id1000's came off of had a aftermarket fuel rail on it. my car has the stock fuel rail still if it makes any difference thanks |
I used a few washers and it worked out great.
Yeah, with my ID2000s, all it is, is a some zinc washers that you can pick up at a hardware store. In my case, I just received 1 per fuel rail mounting post.
yes, pick up (3) 8mm washers.
i have my rc spacers. wonder if those will work? :ponder: |
8mm i.d., normal thickness, .060" or so. One per fuel rail standoff.
my ID 1000's came with 3 little washers that i put on over the rail mounting studs before the rail. i just left the factory manifold grommets in and put the injectors ontop. no mods needed. the id s2000 kit came with the injectors, pigtails to be assembled, and 3 washers. thats all you need.
*dont know if its diff for AP1/AP2 |
yep just 3 8mm washers
