id1000 injectors need spacers?
Old Jun 28, 2010 | 07:50 PM
Suzuka_Joe's Avatar
Default id1000 injectors need spacers?
i bought some id1000's and didn't get spacers with them. friend of mine has some and he got spacers with them. Do i need them? call T1 and just get them from those guys i guess?
the car my id1000's came off of had a aftermarket fuel rail on it. my car has the stock fuel rail still if it makes any difference
thanks
Old Jun 28, 2010 | 07:54 PM
dsddcd's Avatar
I used a few washers and it worked out great.
Old Jun 28, 2010 | 08:51 PM
D1sclaimer's Avatar
Yeah, with my ID2000s, all it is, is a some zinc washers that you can pick up at a hardware store. In my case, I just received 1 per fuel rail mounting post.
Old Jun 28, 2010 | 09:03 PM
JuicedS2K's Avatar
yes, pick up (3) 8mm washers.
Old Jun 28, 2010 | 09:26 PM
Suzuka_Joe's Avatar
8mm thick? for clarification
i have my rc spacers. wonder if those will work?
Old Jun 28, 2010 | 10:14 PM
tony1's Avatar
8mm i.d., normal thickness, .060" or so. One per fuel rail standoff.
Old Jun 29, 2010 | 04:37 AM
JuicedS2K's Avatar
correct, 1 per stud (3 studs)
Old Jun 29, 2010 | 11:52 AM
Suzuka_Joe's Avatar
Thanks tony. i hoped you'd chime in
Old Jun 29, 2010 | 01:25 PM
teamvalorracing's Avatar
my ID 1000's came with 3 little washers that i put on over the rail mounting studs before the rail. i just left the factory manifold grommets in and put the injectors ontop. no mods needed. the id s2000 kit came with the injectors, pigtails to be assembled, and 3 washers. thats all you need.
*dont know if its diff for AP1/AP2
Old Jun 29, 2010 | 01:39 PM
sohc_mshue's Avatar
yep just 3 8mm washers
