ID2000's + single Walbro 255 + stock lines & e85 ?
Old May 5, 2013 | 08:21 PM
siadam's Avatar
Default ID2000's + single Walbro 255 + stock lines & e85 ?
As the title states, any idea what it will make, I do have a Kenne Bell Boost a Pump, I can crank up if need be.
Thanks in advance.
Old May 5, 2013 | 10:14 PM
riceball777's Avatar
probably 500-550whp, The pump is the limiting factor. I would just from in an e85 walbro 450lph pump. Thouse are known to make 700whp on e85
Old May 6, 2013 | 07:40 AM
siadam's Avatar
I've got a dual pump hanger and a FB 270/290lph (forget which it is) I can drop in to help.
I'm fine on that for now. Still working on my house, but I want to get this thing back on the road with a quickness.
However, I'd be interested in getting that, if a single pump would get me there.
Old May 6, 2013 | 12:09 PM
siadam's Avatar
Does anyone have any experience with that pump?
Old May 6, 2013 | 01:46 PM
Timmay208's Avatar
single 255 is gonna be maxed out 550 for sure, even at that its gonna be at its limit after 500, just do the single walbro 460
Old May 6, 2013 | 04:31 PM
stantaur's Avatar
Currently running the E85 Walbro 400 (properly wired, w/relay & thick-gauge wire) flowing corn juice through ID2000s I got from Tony at T1 (great buying experience with my ID1000s before & tried several other options before selling me the ID2000s when I needed more fuel).
Very happy with the Walbro 400 pump (Portland Speed Industries installed it & has been a huge help with tuning on E85) - it's silent vs. the Walbro 255 it replaced. No flow problems either - stock pressure FPR and low 50s duty cycle at 13 PSI.
Old May 6, 2013 | 05:06 PM
camuman's Avatar
Ditch the pump you lazy bastard!
Old May 6, 2013 | 06:27 PM
siadam's Avatar
So who has gotten big power from it ?
Sent from my iPhone 5 using Tapatalk.
Old May 6, 2013 | 10:33 PM
if you look at my signature you can see my dyno chart. I made 501whp with my walbro 255. This was with e85 fuel on 17psi of boost on stock fuel pressure with id 1000cc injectors. At that point the injectors were close to 100% duty cycle.
Old May 6, 2013 | 11:22 PM
soulicious's Avatar
Nice, but isn't that on Church's dyno?
