Ideal turbo for InlinePro log T3 manifold?
Old Dec 28, 2012 | 07:09 AM
SpeedxRacer's Avatar
Default Ideal turbo for InlinePro log T3 manifold?
Hello,
I tried searching but there are just too many topics to filter through. I want to get a simple turbo setup for my car and will most likely pick up a InlinePro T3 log manifold for simplicity. What turbo would be ideal for a quick spooling setup? Dont want to get crazy, 325-350whp would be ideal for me.
Thanks!
Old Dec 28, 2012 | 07:22 AM
spdracerut's Avatar
Originally Posted by SpeedxRacer
Hello,
Thanks!
A Garrett GTX3067 in a small A/R turbine housing should do the trick.
Old Dec 28, 2012 | 07:24 AM
liquidgsr's Avatar
If your going that much and not higher I'd go with the gt30. The gtx would be if you are trying to shoot past that and make more power in the higher rev band.
Old Dec 28, 2012 | 07:45 AM
Would something like this be ideal?
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
Old Dec 28, 2012 | 09:36 AM
spdracerut's Avatar
That can work, but it's bigger than you really need. That is a 500whp turbo. Like I said, the GTX3067 which uses the 67mm diameter compressor wheel from the GTX2867 but the bigger turbine wheel from the GT30. By going with the smaller compressor wheel, it will spool up faster and have better transient response.
http://www.atpturbo.com/mm5/merchant...egory_Code=GTX
Old Dec 28, 2012 | 04:07 PM
s2klariat's Avatar
Garrett is great, but could also try a 5252 from Precision. Cheaper, same power output. Honestly, you might even be able to go smaller than that for those power goals. If you are certain you wouldn't want more later, go with the smallest turbo with the highest flow possible. Fast spool, but won't fall off up top. Legit/fun street machine.
Old Dec 29, 2012 | 04:55 AM
sohc_mshue's Avatar
For that power range a Garrett to4e will work well.
Old Dec 29, 2012 | 08:10 AM
camuman's Avatar
Does the 5858 fit?
You will want more trust me.
Old Dec 30, 2012 | 07:34 AM
sohc_mshue's Avatar
I agree he will want more. That much power in this car feels like a dog....or im just used to more haha.
Old Dec 30, 2012 | 11:22 PM
ScorpionT's Avatar
You would be hard pressed to get that much from it. I would go with the GT3076R to save money, or the GTX3071R for a little quicker spool if you dont mind spending the extra money. Either will give a little margin for error (bad tune, fuel, etc...) as well as room for more power in the future.
StocS2k
May 19, 2017 11:45 AM
Blackpearl05
Jul 26, 2009 03:20 PM
