Idling A/F Ratio High
Old Dec 26, 2008 | 02:53 PM
crav3s2k's Avatar
Thumbs down Idling A/F Ratio High
Hey guys I recently installed an inline pro turbo kit with aem ems. I got it tuned a few days ago and starting today my a/f readings started to jump from 15 to 16. I'm worried that my car is idling really high. I guess my question is that what could be the issue?
Thanks
Old Dec 26, 2008 | 02:55 PM
Enthralled's Avatar
when I had my Vortech, my AEM wideband would jump all over the place at idle, but tried to stay around 15 or so.
Old Dec 26, 2008 | 02:58 PM
crav3s2k's Avatar
its weird it stays around 13 - 14 then few seconds later jumps from 14 - 15 and then jumps around to 15 - 16
Old Dec 26, 2008 | 02:59 PM
crav3s2k's Avatar
when it hits 16 theres a little vibration from the engine, its like a little rev
Old Dec 26, 2008 | 06:17 PM
JoeyBalls's Avatar
My car idles at like 12 when really cold, but when warmed its pretty much pegged at 14.7, at idle the motor is under lil load, what does it read WOT
Old Dec 26, 2008 | 07:16 PM
Wardroid's Avatar
that's normal.. you also want to be around 15ish, when cruising low rpm..
Old Dec 26, 2008 | 07:48 PM
crav3s2k's Avatar
Oh I see, I was just getting a little worried, because before I noticed that I was idling around 12 - 14.9. It just started getting higher and higher. What does WOT mean?
Old Dec 26, 2008 | 08:37 PM
Wardroid's Avatar
Wide Open Throttle. You should be hitting 11, when stomping on the pedal. If you're at 12 at idle, then that would be a problem. It'll mean that you're running way too rich and you'd be getting like 5mpg
Old Dec 26, 2008 | 09:02 PM
crav3s2k's Avatar
Oh sorry I forgot to mention I only hit 12 on cold start
Old Dec 26, 2008 | 09:03 PM
crav3s2k's Avatar
So its normal to hit 16 at idle?
