Injector duty cycle and AFR
Old Jul 7, 2011 | 07:58 AM
s2konroids's Avatar
Default Injector duty cycle and AFR
Guys,
I have 440cc injectors and I'm considering moving up from a 7psi to 9psi on my CTSC+AC, looking at my GEMU logs its 75% duty cycle at redline, below this is obviously tapers up. My AFR is around 12.2 throughout in vtec @4k - A friend said at my boost levels, UK weather and way I drive i could goto 12.4 MAX afr but still have to taper down at redline.
My question is would i 'roughly' have enough headroom to run 9psi or would it push past 85% DC?, 85% is what i consider the limit (without going static) thus i wouldn't like to go any further (considering where i live i cant hoon the car a lot), what % would it likely go upto?
cheers
Old Jul 7, 2011 | 09:28 AM
camuman's Avatar
i would upgrade your injectors to id725 or rc 650. maybe even just step up to a id1000 or bosch 900 for future upgrades. it sounds like overkill, but thats what i said when i was running 650's lol. now i am on bosch 900's and wish i had just went id2000
Old Jul 7, 2011 | 09:30 AM
s2konroids's Avatar
Thanks.
Sure i can always put bigger injectors in, but i just want to know if there is scope duty cycle wise on the current ones?
Old Jul 7, 2011 | 09:32 AM
camuman's Avatar
i feel you will be pushing them. rc engineering has a fuel injector calc, and it will show you that at stock base fuel pressure, 440's dont do much. lemme dig up the link.
http://www.rceng.com/technical.aspx
its ballpark of course. but helps.
Old Jul 7, 2011 | 09:34 AM
s2000Junky's Avatar
Originally Posted by Irvatron
Guys,
cheers
8psi should be fine. 9psi would be pushing it past 85% i'm pretty sure. Doest take but a little time to throw on the pulley and start tuning WOT/open loop with your buddy to see where you’re at though AJ. Might get lucky. Could bump up the static fuel pressure just a bit. 50-55psi? But then you have complicated your tune, with likley needing to get into closed loop calibrating on your emanage again. I think it could all be done though. Might want to bounce this off Brad.
Old Jul 7, 2011 | 01:28 PM
s2konroids's Avatar
Could do Brad.
Do you know if a comptech 4.0" pulley will net me 8psi (7.5psi +ac).
According to this it should???
For Comptech:
4060400 Standard AP1
4060395 4.25inch -------------------- I must be running this stock AP2 pulley on my ap1 to net 7psi (6.5+ac)??
4060390 4.0inch(7#)
4060385 3.5 3.35inch
4060380 3.25inch
4060370 3.0 inch
Thanks
Old Jul 16, 2011 | 09:53 PM
s2000Junky's Avatar
Yes i saw 8psi at 9k with the 4"
CTRLFRK
May 1, 2018 09:22 AM
08s2000CRbackinblack
Mar 31, 2013 06:29 PM
ctb2024
Oct 19, 2008 09:08 AM
btstone84
May 13, 2008 07:02 AM
busterpit23
Feb 29, 2008 02:34 PM
