injector impedence
Old Nov 28, 2007 | 07:35 AM
syellow's Avatar
Default injector impedence
I have read a few different things on these forums...
1. I read you need an injector resistor box if you use peak and hold rc injectors, but you don't if you use saturated.
2. I also read you only need an injector resistor box if the injectors are 750cc or higher.
Which one of these is correct? I have rc peak and hold 600cc injectors. I have the resistor box ready to install. Please clarify. Somebody who really knows what's going on please respond.
Old Nov 28, 2007 | 07:40 AM
Soul Coughing's Avatar
rc750 do not need a resistor, although 1000c rc's do. IP 880 and 620 need a resistor box etc...
Old Nov 28, 2007 | 08:10 AM
misz's Avatar
RC makes both sat and p&h 750. I belive you need the box for all p&h regardless of injector size. Correct me if iam wrong.
Old Nov 28, 2007 | 08:40 AM
that is true, but you can get 750 cc RC's without a resistor box! whereas the 1000cc RC's do!
Old Nov 28, 2007 | 11:30 AM
ChefJ's Avatar
not to go off subject but isn't there a company that makes 880cc injectors that are saturated
Old Nov 28, 2007 | 12:00 PM
Spoolin's Avatar
With the EMS or even the stock ECU, you will need an injector driver box or resistor box if you go over 750cc injectors with the RC's. 750's are the largest you can go with as a saturated injector.
If you go with a saturated injector, you can just plug them straight into the wiring harness, if you go with a peak and hold, you will need a driver box or resistor box wired in.
Old Nov 28, 2007 | 04:37 PM
chairmnofthboard's Avatar
what's the difference between P&H and Saturated? Why would you want to use P&H?
Old Nov 28, 2007 | 05:49 PM
syellow's Avatar
peak and hold are supposed to be better when delivering fuel. Also RC doesn't make certain injectors that are saturated. The stock s2000 injectors are saturated.
Old Nov 29, 2007 | 09:14 AM
Spoolin's Avatar
Yes, peak and hold are much better and saturated injectors only go up to a certain size. If you want bigger injectors for your specific power goals, you will have to change to peak and hold.
scottieboy561
Jul 2, 2009 09:24 AM
s2mmkay
May 21, 2009 08:34 AM
TheCarGuy2021
Apr 30, 2008 05:32 AM
jdnissanz
Dec 6, 2007 01:33 PM
cjb80
Dec 2, 2004 06:10 AM
