Injector questions
Old Aug 22, 2005 | 08:02 AM
spoiled@21's Avatar
Default Injector questions
What exactly is the difference between "peak and hold" and "saturated" injectors and which is better suited for SC. My supercharger will be put on this weekend and I am considering the new Emanage ultimate but would obviously like to get bigger injectors to take full advantage of it.
Old Aug 22, 2005 | 11:08 AM
Spaceman Spiff's Avatar
Peak and hold perform like a digital signal, off and on.
Saturated are more analog, varying the fuel like a throttle.
Peak and hold have a faster reaction to fuel delivery and cut-off, but not very useful if you're looking for the "perfect" air/fuel ratio. Preferred by Drag racers and those who auto-x for quick acceleration an engine braking response.
Saturated are exactly the opposite. More efficient for better fuel economy and air/fuel is more effective, but response is slower.
S2000s (and most other contemporary Hondas) are saturated out of the factory, and if you want to change to P&H you will require a resistor box along with your P&H injectors.
Unless you plan on being a fairly competitive racer with your S, I would suggest staying with the saturated set-up.
Good luck
Old Aug 22, 2005 | 11:12 AM
spoiled@21's Avatar
thanks
S~Factor
May 19, 2016 01:51 PM
KraftWerks
May 14, 2013 01:48 PM
cjb80
Nov 13, 2001 09:13 AM
