Inline kit with eManage?
Old Nov 17, 2007 | 01:11 PM
Reagent's Avatar
Default Inline kit with eManage?
Is anybody running an Inline kit with eManage Ultimate?
When I finally get the funds to buy a turbo kit I had been planning on getting the Greddy kit because:
1. I want "bolt-on" performance (no head gasket) with pump gas.
2. I have to have the stock computer to pass smog. (No AEM)
But an Inline kit with small turbo and eManage would also do what I want, so anybody go that route?
Old Nov 17, 2007 | 01:27 PM
Spec_Ops2087's Avatar
Unless you know someone, the turbo kit will not pass emissions despite the computer being able to pass.
Aside from that, yes I used to run an emanage with the IP kit. However, the AEM EMS is 10 times better in all respects.
So yes you can run an emanage, but remember it won't feel stock (unlike the aem)
Old Nov 17, 2007 | 01:56 PM
Reagent's Avatar
It will pass in AZ cause all they do is plug it in. If it doesn't throw a code you're done.
If I "knew someone" I would use an AEM.
I'm well aware that AEM is better. But since I can't use it there is no point in worrying about it.
Old Nov 17, 2007 | 02:06 PM
deathsled's Avatar
IP with emanage ultimate could easily pass obd2 inspection. They don't even pop the hood, all they do is plug into the OBD2 port. At least here in NC that's how they do it.
and about EMU not feeling stock where as the AEM would? are you crazy? You're piggybacking off the stock ecu, so at startup, idle, and no boost it should feel pretty much just like stock if tuned appropriately. With the AEM there is infinitely more potential to not have the car tuned properly and have trouble with startup, idle, tip in, etc.
I've got an emanage ultimate and thats what is going to control my FI setup once I figure out exactly what I'm doing. AEM EMS is just not an option since my car must pass OBD2 inspection.
Old Nov 17, 2007 | 02:07 PM
Enthralled's Avatar
you have other options if you need to retain your OBDII...Hondata and HKS F con V pro.
Old Nov 17, 2007 | 02:15 PM
deathsled's Avatar
also, the greddy kit clearly runs the EMU, I don't think there is any real fundamental difference between turbo kits that would prevent it from not working with an IP kit.
Old Nov 17, 2007 | 02:41 PM
BlownAP's Avatar
which emanage? blue or ult? to completely different animals
Old Nov 17, 2007 | 05:20 PM
[QUOTE=deathsled,Nov 17 2007, 06:06 PM] IP with emanage ultimate could easily pass obd2 inspection.
I've been refering to the blue when I say emanage, when I used the emanage people were still trying to figure out the ultimate.
Old Nov 17, 2007 | 05:29 PM
Reagent's Avatar
I have heard nothing good about the blue. I am talking about the Ultimate. I assumed it was understood that nobody would use the blue any more. I'm surprised Greddy is still selling them.
