Installed new Pistons, Spring Retainers...
Just got my CP pistons (8.8:1), SuperTech Spring Retainers, Dual Valve Springs, and ARP Head Studs installed and when we started it up at the shop, it was making a slight ticking noise. I was wondering if anyone has experienced any noises after installing some of the parts I had done. It is not a super loud noise and it is not a loud knocking noise. Could it be the parts braking in?
Thanks
Thanks
Um, a light clicking noise is usually what you get when your car is low on oil. Did they build positive oil pressure BEFORE turning the motor over? What is your oil pressure? Did they replace the oil banjo bolts and are they lined up correctly (not sure if that really matters, but good to know
After that I know nothing about doing valve jobs. I've helped replace a few pistons here and there back in the day though its been awhile. Like late 80's early 90's
). After that I know nothing about doing valve jobs. I've helped replace a few pistons here and there back in the day though its been awhile. Like late 80's early 90's
Originally Posted by Asura,Aug 30 2005, 05:54 PM
Did you tell CP the pistons were going in a block with FRM cylinder walls?
