installing ARP head studs
Old Sep 15, 2011 | 09:09 PM
9krevvin's Avatar
Default installing ARP head studs
I am installing ARP head studs and I need to know the torque specifications and sequence to tighten them. I did a search and couldn't find anything. Please help!
Old Sep 15, 2011 | 09:10 PM
passmans2kny's Avatar
Old Sep 15, 2011 | 09:11 PM
9krevvin's Avatar
Torque to 30 then 60 then 90? Do you know the sequence?
Old Sep 15, 2011 | 09:22 PM
seoul2k's Avatar
call arp and they should give them to you.. my arp head studs came with the assembly lube and also the sequence and torque specs on a piece of paper(which is with my mechanic)... call em up and im sure they'll help you out
Old Sep 15, 2011 | 11:44 PM
S2000_FUN's Avatar
Here you go
http://arpinstructions.com/instructions/208-4702.pdf
Old Sep 16, 2011 | 08:20 AM
Sideways's Avatar
Originally Posted by S2000_FUN
ARP is recommending 95 ft lbs torque.
Old Sep 16, 2011 | 08:30 AM
HMFIC's Avatar
jeez...misinformation like a mofo
Old Sep 16, 2011 | 10:29 PM
9krevvin's Avatar
ARP in the instructions recommends 80ft lbs when using their assembly lube. (Which I did) Is this correct?
Old Sep 18, 2011 | 07:28 AM
wadzii's Avatar
Banned
The last set of arp head studs I had told me 100ft/lbs w/their lube.
use the stock sequence and the more steps you do the better in general. start with about 15ft/lbs and them make sure the head is seated all the way around. I fix alot of cars with crushed dowel pins in the head b/c people started cranking the head bolts down and the head wasnt all the way on the block/dowels.
Old Sep 18, 2011 | 08:24 AM
jefferyg32's Avatar
This is the right torque specs when using ARP Lube. (30-60-95)
There can be other specs with other lubricants as they all have different properties. See this clip: http://www.youtube.com/watch?v=mgwmuZuJ02I
The sequence is just per the book. Start in the middle and criss/cross your way to the outside. Repeating the steps 3 times until you achieve 95ftlbs!
