installing gauges
Old Oct 25, 2007 | 07:11 PM
brilliant's Avatar
Default installing gauges
Hey guys, I just got my greddy kit installed, but my shop wanted another 4 hours of labor to install my 2 gauges (boost/oil pressure) and my a-pillar pod. Does this seem about right? How hard is it to do yourself?
Sorry guys i'm new to FI advice will be helpful! thanks!
--David
Old Oct 25, 2007 | 08:10 PM
ChefJ's Avatar
Gauges are easy. Boost is a piece of cake. Its a poisitive and negative for lighting and a vaccum line, mine is t'ed off of the boost controller.
oil pressure is just tough finding the fittings depending on how your turbo is supplied with oil.
Old Oct 25, 2007 | 08:49 PM
brilliant's Avatar
so you think that the 3-4 hrs that my shop estimated is too long? keep in mind this is installing gauges and a-pillar.
Old Oct 25, 2007 | 09:35 PM
myblaks2k's Avatar
^so how it the kit, and how was the installation? sorry for changing the subject.
Old Oct 25, 2007 | 10:53 PM
skibum's Avatar
Running wires up the a-pillar is cake. They just snake along up from the kick panel and up the side of the dash to the pillar.
Old Oct 25, 2007 | 11:18 PM
Spec_Ops2087's Avatar
I installed 4 gauges by cutting INTO the dash and running all the wire and it didn't even take 3 hours. There raping you on the 4 hour charge, it shouldn't be any longer then ~1 hour.
Old Oct 26, 2007 | 10:26 AM
modMonkey's Avatar
4 Hours is WAY too long. Even if you are picky with running the wires cleanly, it should take 2 hours tops.
Old Oct 26, 2007 | 11:36 AM
brilliant's Avatar
thanks for all the help guys!
sunhita
Apr 1, 2008 10:57 PM
Casas
Jan 4, 2008 05:12 AM
brilliant
Oct 25, 2007 06:16 PM
mxt_77
May 17, 2007 01:40 PM
GDM S2K
Dec 17, 2005 12:25 PM
