INTERCOOLER AND MANIFOLD
Old Jan 7, 2008 | 04:13 PM
JERICHO_03's Avatar
Default INTERCOOLER AND MANIFOLD
I WANT TO DO A CUSTOM KIT AND I WANTED TO KNOW WHERE I COULD GET A MANIFOLD AND INTERCOOLER.. I DONT NEED PIPING I GOT A PRETTY BAD ASS SPONSOR SO I JUST NEED TO GET A INTERCOOLER AND MAINAFOLD.. IAM SHOOTING FOR AROUND 350HP ITS GOIN TO BE A DAY DRIVER I WANTED TOP MOUNT MANIFOLD
I DONT KNOW WHERE TO GET THE OIL LINES EITHER IF SOME ONE COULD HELP THAT WOULD BE GREAT..
Old Jan 7, 2008 | 04:47 PM
Soul Coughing's Avatar
CANT YOUR BAD ASS SPONSER HOOK YOU UP WITH A MANIFOLD AND INTERCOOLER? oups i put a question mark on that... should have kept it an open sentence... and make it run on for a paragraph!
search the forums, almost every kit ever made will make 350, depending on if its at the wheels you might need a lower compression HG as well? Why the need for a top mount? You could spec out the lines from Earls, or you could buy a oil line kit, with sandwich plate from the oil cooler etc...
Old Jan 7, 2008 | 05:12 PM
stantaur's Avatar
Top mount mani is nice and provides easy access to the turbo / lines / etc., which is why I'd go that way if I had it to do over. Custom, Pfab or Lovefab are the ones I've read most often.
If you go bottom mount mani, I recommend Full-race, and be sure to specify that you want a V-band housing on the turbine instead of the usual 4 bolt setup. Also recommend bracing the turbo / downpipe to the hole that was left vacant when you removed the lower brace (aka "stay")on the factory header. You can go InlinePro with a cast iron log manifold which may be a better fit for your needs (less horsepower per PSI boost, but lower likelihood of cracks).
Precision has a great intercooler. Your call on whether you mount it low & in front of the frame rails or if you notch the frame rails (and intercooler tabs) allowing you to recess it and retain the factory grille protection.
Stanford
Old Jan 7, 2008 | 06:20 PM
SoCalIsMyLife's Avatar
I have an intercooler for sale in the "for sale" section. bar and plate 22x11x3" core. 2.5" inlet/outlet
Old Jan 8, 2008 | 05:29 PM
dshen921's Avatar
rev hard sells a cast manifold that's only like 2 or 3 hundred. Not a bad deal but not top mount.
Old Jan 9, 2008 | 05:48 AM
s2klove04's Avatar
i have the lovefab mini-me manifold. havn't put it in yet but the welds and everything looks really strong...
Old Jan 10, 2008 | 01:52 PM
AusS2000's Avatar
Quite a few of the MiniMes have cracked.
Mine cracked below the turbo flange and about 270 degrees around.
Old Jan 10, 2008 | 04:30 PM
iDomN8U's Avatar
While were on the subject , which manifold is the most "user friendly" in terms of non-frame notching and reliability?
Old Jan 10, 2008 | 04:44 PM
weiRtech's Avatar
go to www.stealthmodeperformance.com for your oil lines. steve is the man and can hook you up.
Old Jan 10, 2008 | 07:52 PM
afwfjustin's Avatar
shhhh don't mention the minime cracking. I don't need anymore problems
Charper732
Mar 17, 2017 12:48 AM
08s2000CRbackinblack
Sep 8, 2010 08:28 PM
S2000_FUN
Nov 26, 2009 06:19 AM
AP2uner
Aug 8, 2009 02:29 PM
