Issues on the Dyno
Old Sep 18, 2015 | 11:46 AM
E4RTH WORM JIM's Avatar
Just spoke to CT Engineering and they say otherwise.
On the new kits they sell its bottom feed, bottom drain.
That's why I got an extra long oil line in the kit.
Old Sep 18, 2015 | 08:43 PM
lleron's Avatar
What was their logic behind this? That makes no sense to me, as the feed oil is fighting the pressure head from the existing oil in the blower and what guarantees that oil reaches the top of the gears?
I feel that it wouldn't hurt to switch it as 100s if not 1000s of people have run with the top feed oil line with no issues just to see if it resolves your problems.
Old Sep 18, 2015 | 11:06 PM
s2k manic's Avatar
i agree with lleron feed on top drain on the bottom been that way sense the first novi 1000 i helped a buddy put on his 5.0 in 1996 i have lost faith in ct there parts guys for the most part now sense the split call sos i bet they will confirm what has been already said. i will confirm in a few weeks as i will be getting mine in the mail
Old Sep 19, 2015 | 12:10 AM
Ive ran a novi 1000 for a few years now with a top mounted feed also.
I've asked CT to speak to Paxton and justify why, as I agree that the top mounted position has never been an issue for me.
I just need to know that the oil squiter fitted is suitable for the top and has the same flow rate as the older systems.
Old Sep 19, 2015 | 10:20 AM
killerbee_vr6's Avatar
I have a new (2014) CT 1200 kit with top feed and bottom drain, as configured by them. Who knows.
Old Sep 21, 2015 | 08:22 AM
Chitoki's Avatar
Get this worked out yet?
Old Sep 21, 2015 | 08:40 AM
I'm working on it. I have replaced the vtec solenoid gasket and have rev'd the car to deadline, and it made it all the way so I'm not 100% sure.
The car needs to me map again which it is booked in for on Wednesday.
I am still awaiting confirmation from Nate about the oil squirter position.
As soon as I know the one I have installed will fit and not foul the gears it will be getting moved to the top.
Old Sep 21, 2015 | 08:50 AM
Installation
Vtec block connection
And if you look where the torch is shinning you can see the connection point to the squirter
Old Sep 21, 2015 | 09:38 AM
CoolGuy094's Avatar
Nah, that can't be right Jim. Every Novi blower I have seen on our cars feeds at the top. My N1220 conversion onto an old Comptech kit had the feed at the top. The port is clearly visible in your second picture. I don't see any reason why your existing fitting can't be swapped to the top position, and use the plug currently in the top position to plug the bottom port.
Old Sep 21, 2015 | 11:09 AM
JawKnee's Avatar
Originally Posted by lleron
... When I received a new Novi 1200 from SOS I had to move both the drain fitting and the oil feed fitting. There are multiple ports on the blower to allow this. ...
Same here although mine is a 1220.
