Just Dynoed My Car Inline Stage 1 on E85
Old Jan 14, 2012 | 05:05 PM
sohc_mshue's Avatar
Default Just Dynoed My Car Inline Stage 1 on E85
Hey guys just thought I would share my dyno numbers from today. I'm pretty happy with the results.
Setup:
Bone Stock F20
Inline Pro Stage 1 kit
PTE 5865 turbo (small turbo that comes with the kit)
ID2000 Injectors
AEM FPR
Inline Pro Fuel Rail
Walbro 400lph pump
Inline Pro 3" Exhaust
AEM Series 2 with boost solenoid
Tuned on 21psi with E85.
Dyno Chart:
Here is a pic of the car
I will hopefully get it to the track this year once I can afford a Ford 8.8 Rear .
Old Jan 14, 2012 | 06:19 PM
DFWs2k's Avatar
How did the walbro do? Think that fuel setup had more in it?
Old Jan 14, 2012 | 06:56 PM
sohc_mshue's Avatar
Yes it was not close to being maxed out. The fuel pressure held steady all the way to redline without dropping and injector duty was about 63%. I was running 45psi base pressure. The datalog showed fuel pressure climbing to 65psi and holding until redline.
Old Jan 14, 2012 | 07:00 PM
Torque Obsessed's Avatar
Damn that's a sweet torque curve and great results for a stage 1 kit. E85 FTW!
Old Jan 14, 2012 | 07:02 PM
Deception's Avatar
damn good #'s for a log..
how did you get the walbro 400 to work with the stock hanger?
Old Jan 14, 2012 | 07:08 PM
sohc_mshue's Avatar
Thanks!
Old Jan 14, 2012 | 07:09 PM
DFWs2k's Avatar
You just cut about a half inch of the plastic off. I have pictures in my walbro 400 lph thread.
Old Jan 14, 2012 | 07:10 PM
sohc_mshue's Avatar
I cut the hanger and made sure the pickup sat about at the right level to work with the tank level float.
Old Jan 14, 2012 | 07:26 PM
dsddcd's Avatar
Looks nearly identical to mine on C16! I will have to check out the 400LPH pump, that sounds promising.
Old Jan 14, 2012 | 07:32 PM
DFWs2k's Avatar
Did you rewire the pump/is it rewired from previous set ups?
Sent using free Tapatalk - Android FTW
