Just finished Vortech install
Old Nov 19, 2006 | 07:12 AM
TheCarGuy2021's Avatar
Default Just finished Vortech install
Well I just finished installing my Vortech supercharger kit and the car will not start. I'm thinking it's the electrical work (I used wire crimps instead of soldering), but before I go take my seat out and lay on my back for an hour soldering them all together, do you have any ideas of anything else it could be?
Old Nov 19, 2006 | 08:07 AM
John_Z's Avatar
Does it turn over? Can you hear the fuel pump prime? You'll most like end up soldering the connections. Also do not follow the black box wiring diagram as it's wrong. Follow the written directions.
Old Nov 19, 2006 | 08:11 AM
I followed the diagram, not the written. It turns over, and I'm not sure if I hear the fuel pump, but the fuel pump install was pretty simple so I doubt it's that. I'll go redo everything according to the written instructions, thanks.
Old Nov 19, 2006 | 08:12 AM
icemans2k02's Avatar
turn the car over and listen for a 5 second whine, if you dont hear that get some carb cleaner and spray it in TB.
Old Nov 19, 2006 | 08:13 AM
btw i did not soilder my connections either
Old Nov 19, 2006 | 12:26 PM
Hmmmmm.... I went and compared the written instructions and the diagram and could not find any differences. I did undo all the connections and start over following the written instructions soldering in some spots, using quick connects in others. Still no dice. I pulled out a spark plug and put it in the coil and turned it over holding the tip with my finger and watching closeley, and I didn't get zapped or see any spark.
Any other ideas?
Old Nov 19, 2006 | 02:07 PM
ok do this, unplug map clamp and timing box and then try starting it, as long as you dont hit boost you are fine, just start it up. if you feel uncomfortable doing this then just go ahead and take the aftercooler off then try starting it, this will narrow down if it is electrical or mechanincal
Old Nov 19, 2006 | 02:08 PM
C45P312's Avatar
I didn't solder mine and it started right up. Most likely electrical.
Old Nov 19, 2006 | 02:12 PM
nevermind post was irrelevant
Old Nov 20, 2006 | 10:00 AM
Well I rewired it back to stock form and it started right up. Drove it home (down the street) from my neighbors HEATED shop. I'll go rewire everything AGAIN and see if I can get some results. If not do you think it's the black box? The kit was used and they both worked for the previous owner.
