Just had my greddy kit put in....
Old Oct 31, 2008 | 04:22 PM
RangOs2000's Avatar
Default Just had my greddy kit put in....
Hey,
Just had my greddy kit installed and i have a couple issues.
1. The car is much faster before vtec, but as soon as it kicks in i feel like power is lost. I did a search and found that this is usually because of the crappy basemap. So my question is what should i do, get a new tune? or something else?
My setups:
- Stock Cat
- Nuespeed Exhuast
- Stock greddy Kit
2. My second question is my apexi avc-r is reading the speed completely wrong, It says i am doing 80km/h in reverse? Anyone know whats up?
Thanks in advance
Old Oct 31, 2008 | 04:31 PM
Slows2k's Avatar
The Nuespeed Exhaust lost power on NA cars. It's not helping the turbo.
Old Oct 31, 2008 | 06:08 PM
RichV's Avatar
Get a tune and a good 70mm exhaust and that should help things up top. Also consider getting at least a high flow cat, if not a test pipe. that stock cat is a exhaust flow killer.
Old Oct 31, 2008 | 09:00 PM
RangOs2000's Avatar
Alright thanks for the help, would a stock exhaust be better than the neuspeed?
Old Nov 1, 2008 | 05:22 AM
Slows2k's Avatar
It would be better than the Neuspeed
Old Nov 1, 2008 | 05:47 AM
JoeyBalls's Avatar
The old Vtec Killer Greddy Turbo Kit haha, Keep you exhaustr get a Test Pipe and Tune.
I have a Berk HFC and though I spike a little bit CREEP is gone, I "reset" the Flapper arm to 3 turns I am not sure what it was set at, but it was too tight seems to handle BOOST much better now.
Old Nov 1, 2008 | 07:48 AM
M.A.R.C.'s Avatar
Originally Posted by RangOs2000,Oct 31 2008, 08:22 PM
Hey,
My setups:
- Stock Cat
- Nuespeed Exhuast
- Stock greddy Kit
Thanks in advance
does the car break up any past vtec? which plugs are you running? if they're stock i'd try colder plugs
Old Nov 1, 2008 | 09:16 AM
RangOs2000's Avatar
It does break up, im definatly going to get colder plugs today. Thanks for the help guys
Old Nov 1, 2008 | 10:15 AM
M.A.R.C.'s Avatar
It's a high possibility then that could be your issue. The spark is likely getting blown out. Change the plugs out and let us know
Old Nov 1, 2008 | 11:31 AM
RangOs2000's Avatar
Changed the plugs, its much better, no breaking up. I love it. I feel though it still needs a tune, i will get that done when i get a hfc and all my gauges hooked up. Thanks for the help, if anyone knows whats up with the boost controller let me know. Or if you have a avc-r what your setting are.
Thanks a lot
