K-Pro and GM Map Sensor settings?
Old Apr 22, 2009 | 10:05 AM
0piston's Avatar
Default K-Pro and GM Map Sensor settings?
HI I have the GM 3 Bar Map 12223861, trying to figure what to put in the Map Sensor config.
I've been on the hondata forums, etc.. lot of misinformation saying that it can be configured as a Motec 3 bar, a MSD 3 bar, or custom scaler: 628
offset: 0
I was hoping someone on here would know..
thanks
Old Apr 22, 2009 | 01:21 PM
JustinC's Avatar
neetronics or motec work the best
Old Apr 22, 2009 | 01:30 PM
Boofster's Avatar
Speaking of which, does anyone know the SOS 3bar numbers?
Old Apr 22, 2009 | 07:04 PM
518135's Avatar
Does this help?
Old Apr 23, 2009 | 03:09 AM
d-j's Avatar
d-j
My settings....FWIW
Motec 3 bar
scaler: 609 mbar/volt
offset: 2 mbar
Old May 27, 2009 | 01:17 PM
Boofster's Avatar
Originally Posted by 518135,Apr 22 2009, 07:04 PM
Does this help?
Yeah I got that sheet but maybe I can't read it correctly.
This is what you get on the KPro (SoS 3bar):
With the "load" values above it doesn't sound right.
Someone correct me!
Old May 27, 2009 | 02:05 PM
JustinC's Avatar
you are correct, these values do not help you with k-manager. I would recommend you contact SoS for the proper values
