Kings Oil catch can
Old May 30, 2013 | 08:42 PM
Redline S2K's Avatar
Default Kings Oil catch can
Ok so most catch can setups have breathers with two hoses going to the can. Any reason the Kings only has one and does it make a difference?
Old May 31, 2013 | 02:41 AM
gettin it's Avatar
Not really, depends on your clearences if the motor is built to specs. Stock motors don't need to have a can. I have one on my setup as well. However, if your looking for a catchcan setup, Dwight at Stage 6 can build you one. He built mine, Ceasers, and will be doing Elliots more then likely.
Old May 31, 2013 | 04:51 AM
I want one thats a coolant res and catch can. I hate that plastic overflow eyesore.
Old May 31, 2013 | 05:46 AM
gettin it's Avatar
Awa, ok.
Old May 31, 2013 | 08:55 AM
siadam's Avatar
Incorrect.
Once you understand the role of a PCV style setup, and understand what happens to your motor under boost conditions, you will understand the need & benefit for a catch can.
jdnissanz
Apr 6, 2009 01:03 PM
stopmenot2002
Apr 14, 2008 06:12 PM
S2000TigerGirl
Jun 8, 2007 05:48 PM
